On a power steering gear box the outlets are TWO different sizes.
Is the larger inlet the low pressure return line to the pump????
I am plumbing a Hydro Booster and this is what i gather to do...........
From the P/S pump High pressure out to Hydro Booster from the Hydro to the steering box high pressure side......
Low presure from the P/S pump to a "T" fitting and then a return line from the gear box and also a return line from the Hydro booster to the "T" fitting........
Thanks
Bg
Thanks
Bg
