Plytmouth 1941 4 door custom - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2007, 10:58 AM
Parisienne70's Avatar
My friend is beginner to do hot rod
This car is for daily driving
He want chevy 350 with overdrive transmission, (fuel pump)
With the original frame , he can put 350 ???
The front end he want disk brake, the best setup to do this ??
He can use the original suspension ??? or he need change everything , suspension, direction .....
For the rear end , he want put large tire inside , what the good rear end for do this
He want put ,part easy to find
Ty
Old 10-02-2007, 05:32 PM
lowgirl's Avatar
Plymp
Is this a joke or am I in a dream
Old 10-03-2007, 10:39 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Welcome to the site. You will find a lot of info and help here. You can use the search engine and Knowledge Base (links at the top of the page) to find quick answers to your questions. As well check out the Project Journals for info and inspiration.
This is not a joke or a dream. Parisienne70 is from Montreal, Quebec, Canada. The first language spoken there is French. I know that if I had to post a question in French I would not do as good a job as he has.
Building a daily driver on that original frame will be possible for a beginner if he uses many of the kits that are available. A 350 and overdrive transmission is a good way to go. As for a fuel pump he could use an electric one mounted next to the gas tank.
By the time you rebuild an original front suspension and add a disc brake kit you will be probably further ahead to go with one of the ifs kits with disc brakes. Street Rod Engineering is just one of many that makes these.
http://www.streetrodengineering.com/...gllifskits.htm
For the rear end I am not sure what to use but there are several members on the board building early 40's Mopars and maybe they will see this and give you some answers. Again several manufacturers have kits available to help you install a rear end once you decide on what you will be using.
If you have any more questions get back to us and we will see if we can help.
1941 Buick. Just want the best devious Suspension - Brakes - Steering 3 05-30-2007 09:13 AM
1941 Willys Pickup DarellGLewis General Rodding Tech 14 12-02-2004 10:13 PM
1941 chevy frame help pat-tracy@marshallne Suspension - Brakes - Steering 3 07-31-2004 10:59 PM
Steering wheel column length for 1941 Jackyl Interior 2 07-25-2004 02:36 PM
Will a 1941 1/2 T P/U Tailgate fit on a 1945 ford 1/2 t p/u biglee550 Suspension - Brakes - Steering 2 06-11-2004 09:03 PM
