Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pneumatic tool for pitman arm removal
Old 11-05-2009, 06:58 AM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Yeah the pitman arm is a wear component on this truck and I won't be reusing it. Just wondered if you guys had more luck using a pneumatic hammer and picklefork-type tool for pitman arm removal from the steering box.
Some other guys swear by gettign an angle grinder and cutting a notch out of the pitman arm close to the splines, then hitting it with the puller. Seems appropriate that the thinner metal would allow more flex...
K
