Pneumatic tool for pitman arm removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2009, 11:30 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Hey guys-
I was looking at harbor garbage today, and I see there's a cheap set of joint separators as well as an air hammer for low buck. http://www.harborfreight.com/cpi/cta...emnumber=47868
and
http://www.harborfreight.com/cpi/cta...112&zmap=66315
I've only used a standard puller before, but its always been a HUGE pain to get these things off. I hear the secret is to use one of these pneumatic devices. Would this setup have the guts to pop the joint for me?
Thanks-
K
Old 11-04-2009, 07:19 PM
Last journal entry: frame build
MO Those have ruined more ball joints and tierod ends than dirt. They are guaranteed to ruin the seal and usually damage the socket so the joint is loose. A couple strokes with a BFH backed up by another BFH will pop loose the most stubborn ones. One on each side of the socket the tapered stud goes through. If it is hanging by the stud, a couple good hits and it will fall out. If out is up, after a couple good hits, tap the end of the stud with the nut screwed on flush and it will usually come right out.
If you have to have a special tool, get one that grips under the socket and pushes on the stud. Even these require a tap on the puller screw with a hammer to pop them loose.
Old 11-04-2009, 07:24 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Only use a pickle fork if you will not be reusing the components. They are fast, but they butcher the parts.
Old 11-04-2009, 07:30 PM
Wiki Edits: 31
yea, pickleforks are quick but only use them if your replacing parts
Old 11-05-2009, 06:58 AM
Wiki Edits: 3
Yeah the pitman arm is a wear component on this truck and I won't be reusing it. Just wondered if you guys had more luck using a pneumatic hammer and picklefork-type tool for pitman arm removal from the steering box.
Some other guys swear by gettign an angle grinder and cutting a notch out of the pitman arm close to the splines, then hitting it with the puller. Seems appropriate that the thinner metal would allow more flex...
K
Old 11-05-2009, 04:22 PM
weirdbeard's Avatar
1976 Ranchero GT
I'm not sure a pickle fork would even work to get the pitman arm off the box. I have always just used a 20 dollar pitman arm puller. It is worth the money. The cheap ones say not to use pneumatic tools to turn them. It really doesn't take that long though even just using a socket wrench.
Old 11-06-2009, 04:30 AM
vettedreams2001's Avatar
Ethylene Glycol and OJ, Mmmm!
I love those, works great when you can't get a good swing on a hammer or if hercules torqued it. Like everyone has said it will ruin it, but if replacement was premeditated, than go for it.
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 07:24 PM
Best tool for floor pan removal? Bilko Body - Exterior 5 12-29-2006 10:53 PM
A Arm bushing tool propaneburner Garage - Tools 5 07-12-2006 07:05 AM
New Scan Tool user 36scsc Electrical 3 01-29-2005 07:35 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
