PO128 OBD-II trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2010, 06:36 PM
79z28's Avatar
79 Camaro z28
Last journal entry: rear wiring harness off
My mother wasn't too bright and poured oil in the coolant reservoir, i flushed it out 4 times and siphoned the oil on the top out about a week later. My code reader says http://www.obd-codes.com/p0128 Could the sensor go bad after that happened? Her car is a 2004 Saturn Vue with almost 60k miles.
Old 08-29-2010, 08:21 PM
LATECH's Avatar
well it happens. The code p0128 is described as " coolant temp too low for run time elapsed" basically means that the engine did not warm up fast enough for the engine to complete all its monitors and go into closed loop in time required.Maybe it isnt warming up at all. I would pull the sensor out and see if a load of schmeg comes out of it location in the cooling system . I would think that oil coolant mix (schmeg) would not transfer heat to the sensor.
It may also be just an air pocket that is stubborn and doesnt wanna go away.
Before you go through all that begin with the engine cold then clear the code and then drive it for a little while say 10-15 minutes. then put the scanner back on it and look at pending (or one trip) codes to see if it comes back.A lot of codes take 50 drives cycles to reset.
Old 08-29-2010, 09:06 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I doubt there's any damage to the sensor from what you describe. Check you're thermostat, some fail in the open position, not allowing full warm up.
Semper Fi
Code Reading OBD II SCANNER ??? FFredericks Engine 4 10-28-2007 01:59 PM
Obd II J Cal Engine 7 12-12-2004 07:29 PM
obd II scanner k-star Engine 1 09-08-2004 02:05 AM
Please Help with OBD II bluesman123 Engine 0 10-27-2003 05:16 PM
OBD II test xtreme off-road Engine 3 12-07-2002 06:44 AM
