Pocket porting Vortecs.Worth the time ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2013, 05:10 PM
jokerZ71's Avatar
Wrench Turner
Doing some odd & end things to engine & heads while it's apart for a rebuild.I have a somewhat pronounced ridge just below the valve seats.The ridge is pretty much all the way arond port,but,less noticeable on the floor section.Is it worth the time to clean up & blend this ridge on a set of 906 Vortecs?
Old 08-17-2013, 05:28 PM
jokerZ71's Avatar
Wrench Turner
I meant to post this in the "engine" forum.Sry,I didn't realize I was in the "basics" forum.Pleeze feel free to move it if necessary.
Old 08-17-2013, 09:45 PM
vinniekq2's Avatar
Porting and clean up is always a good thing,as long as the casting is up to the mods.The vortec is a very good small head with limitations.If you have the time and tools then go for it.
Fbird88 is one of the guys to talk to about home porting budget heads.
I think 245 ish is about all the CFM you will get on the intake side.The exhaust side is weak so ask fbird how far to go on that side of the heads?
Old 08-17-2013, 10:35 PM
jokerZ71's Avatar
Wrench Turner
Yep.I wuz hopin he would chime in.LOL. I don't wanna get in over my head,or,fool with the ports,but,I do wanna clean em up a little.That ridge & I can feel a slight lip around the chamber.Valves don't seem to be shrouded.
Old 08-18-2013, 08:05 AM
jokerZ71's Avatar
Wrench Turner
I'll blend the ridge I was speaking of & clean the port up.Since this is a truck I'm more interested in low & mid range.Even @ a truck pull I'll be lucky if see over 4500 to 4800 rpm.I usually hit wheelhop,or,spinout befor any serious rpms.Depends a lot on the dirt & how well the track is prepared.Truck weighs over 5000 lbs,so,I won't be drag racing.I will make a few passes befor & after any major work just to see how it responds.Can't afford a dyno,so,my time slips should let me know. There is a slight lip I can feel around the edge of the chamber.If heads end up needing any decking,that should remove that.If not,i'll take it off.It feels sharp & very thin.An article I read stated that for 1 cfm of intake flow increase will give approx a 2 HP increase.Does that seem accurate to you?Thanks for the response.
Old 08-18-2013, 06:32 PM
jokerZ71's Avatar
Wrench Turner
Originally Posted by F-BIRD'88 View Post
I wish it was that easy. ( if you get 2HP per cfm @28" you did a great job {race motor) Yes you can smooth that sharp machined combustion chamber edge with a flat file by hand. No need to get carried away.
Why not fix the truck chassis?
I am planning some front suspension improvents.Gotta get this engine done & then beef up my transmission.I currently only compete for fun 5 to 6 times a year @ local smalltown pulls.Gonna try the mud drags also lateer on.It looks like fun !!!
How Much HP Increase With Pocket Porting beertracker Engine 8 01-28-2010 12:42 PM
Pocket Porting? beertracker Engine 15 01-01-2010 03:51 AM
Pocket Porting Heads?? 1970Chevy Engine 3 06-19-2007 08:09 PM
More pocket porting Vortec q's reddwarf Engine 8 03-02-2003 06:34 PM
pocket porting swoodard23 Engine 1 01-08-2003 06:18 AM
