Points distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2003, 10:02 PM
Post Points distributor
I have an accel points style billet distributor, I am looking to put that in my 86 pro street camaro, and take the msd billet distributor out, my reason is im selling the car and i want to keep the msd for my other car, my question is what should I do to prep the accel distributor, and how do i go abotu setting the points, i know you need to use a dwell meter, but what is the easiest method?
Old 02-24-2003, 01:06 AM
aka Duke of URL
Question
If the points are like the GM, they are adjusted using a hex key tool. You merely insert the tool through the distributor window and adjust until you come to 28 to 32 degrees of dwell.
Old 02-24-2003, 04:48 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
If you don't have a dwell meter, set them close enough to run the motor. Then with the motor running (if it's GM style with the window), turn the screw clockwise until it wants to stumble. Then turn the screw back out (counterclockwise) about 1/3 of a turn.
Oh yeah, don't forget when you adjust the points, keep in mind that it alters the ignition timing (wider gap advances smaller gap retards).
[ February 24, 2003: Message edited by: BstMech ]</p>
