Points to electronic ignition conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 07:32 AM
Does anyone have a wiring diagram to convert a points distributor to electronics using a TP100 module but retaining the points as a trigger device. Don`t know if its possible but any advice will help
Old 05-12-2013, 08:55 AM
bondo's Avatar
Ayuh,.... A quick google search says that module needs a Hall Effect trigger to work....
Old 05-12-2013, 10:16 AM
LATECH's Avatar
An optical trigger would also work. I believe the square wave from either is what will work for it. A permanent magnet (reluctor) may not work due to the type of pulse it creates.
If you look at the waveforms on the oscilliscope,The hall and the optical both create a square wave and a PM creates a sine wave.
Fact is stranger than Fiction
dual points to electronic conversion slow'n'steady Engine 2 07-01-2010 10:00 PM
Upgrade to electronic ignition from points KENMO Engine 15 05-06-2008 08:34 AM
mopar points to electronic conversion legionlleh Engine 3 03-09-2007 10:04 AM
Points to Electronic conversion? tazzman68 Engine 10 01-30-2005 04:04 AM
points and electronic ignition ????????? allnight Hotrodders' Lounge 2 09-21-2002 06:11 PM
