points or HEI dizzy?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 10:28 AM
I asked a question concerning car starting problems. and kain13 asked if it was points or hei dizzy? ummmm,.. whats the difference? was looking to post this on pre-beginner bulletian board
Old 07-25-2006, 11:14 AM
wrnchmaster's Avatar
points are an older type of ign system usually has a small dist cap.. HEI is a electronic system, usuall has a large cap..hei is a much better stystem GL
Old 07-25-2006, 11:23 AM
thanks!
I really bought too much car for a novice. The more I learn, the less I really know. (bare with me)
Old 07-25-2006, 11:30 AM
cabowabo's Avatar
big Q
hei
hei will have the coil mounted on top of the distributor and points wont
Old 07-25-2006, 12:37 PM
1939d2/s10's Avatar
It looks like the car in your gallery has an external coil,but it may not be points,you need to remove the cap and look and see if it has any moving parts,like an arm on the points that rides on the dist cam,if nothing inside looks like its touching it is electronic.
Old 07-26-2006, 08:24 AM
Thanks!
thanks, needed to know where to look...will check it. i believe it's High Electronic Ignition
just found this article which also explains it. (for other beginners)
http://www.hotrodders.com/t44185.html
Old 07-27-2006, 05:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Pull the cap...and rotor..
IF you have these:
It's Points...
If you have this:
It's electronic.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-28-2006, 09:20 AM
1939d2/s10's Avatar
Something told me DOC would be prepared for this,I was trying to say exactly what Doc has shown ,Johnny
setting points on sb chevy frackster66 Electrical 14 03-22-2008 11:33 AM
Conversion chevy 350 to HEI from Points. rapsag Electrical 5 01-03-2006 05:23 PM
points to hei 455c-10 Electrical 1 06-14-2005 07:19 PM
Pulled HEI out,put old points distributor back in, no fire namdlo Electrical 1 08-13-2004 12:19 AM
HEI to points oldsgeek Electrical 3 06-14-2004 01:49 PM
