Points or HEI........what's better? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Points or HEI........what's better?
Stock points 6 3.97%
Stock HEI 53 35.10%
Points with additional electronics 9 5.96%
HEI with additional electronics 71 47.02%
other 12 7.95%
Voters: 151. You may not vote on this poll
Old 07-27-2004, 08:58 AM
poncho62's Avatar
Wiki Edits: 5
I have posted an ignition basics post at the top of the electrical forum. Read it through if you like and let's have a discussion on whats better. Of course, there are variations on these systems and your thoughts are appreciated there too.
Old 07-27-2004, 10:06 AM
Last journal entry: Slow progress
Re: Points or HEI........what's better?
Pretty good Ignition System post. Did you notice this
A DMA (Digital Mullet-Meter)
Very funny! Should be DMM, (Digital Multi-Meter) tho.
I had to answer "other. The after market Capacitor Discharge systems in conjunction with a sensor to replace the points, seem to me to be the best unless you are going "exotic" like one of the new Coil-On-Plug Ignition Systems.
There is an article detailing them at this location
Though it's easier to find burned points than a messed up sensor.
The units from Crane, Jacobs, Accel, etc. are all good. I went with the Crane because it was on sale. Adjustable soft rev limit, hot spark, etc. I had a problem where it died in the rain but after I sealed the adjustment holes I never had another problem.
Some Electronic Fuel Injection systems also provide spark control with indiv. coils for ea. cyl, but I haven't had a chance to try one yet.
For the DIY folks, Heres a site where a project to build a Digital Distributorless Ignition System is underway.
There is a simple course, designed for counter help, at Autotune which has some good basic info on identifying components and trouble-shooting problems, with a test at the end.
Another good site is How Stuff Works (Link to Ignition Systems Section)
Old 07-27-2004, 10:09 AM
poncho62's Avatar
Wiki Edits: 5
Didn't notice that................are you sayng that I need a haircut?...................lol
Personally, I tend to try and keep things simple. I don't need a super high powered ignition system. I have points on my 62 Pontiac and HEI on my truck (Chevy)
Old 07-27-2004, 11:27 AM
figure8's Avatar
I have had good luck with HEI. I have a sreet rod that doesnt have enough firewall clearance for HEI and I don't want to butcher the firewall. Anyone have recomendations for a compact (small diameter ) electronic ignition to replace a points. distributor? Phil
Old 07-27-2004, 03:46 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I don't have expierence with the HEI but I don't mind my points distributor on my 69 F250. Aslong as it keeps sparking I dont worry about it.
Old 07-29-2004, 02:15 AM
docvette's Avatar
Wiki Edits: 12
Try here:
http://www.sallee-chevrolet.com/MSD/...tors/8570.html
Doc
Old 08-12-2004, 08:54 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I have an Accel Super Stock on a small block chevy & an Accel Billetproof on a small block ford.
They both are non-points and have built in electronic ignition module. They look like points distributors, are small in diameter and use small stock round coils.
Old 08-13-2004, 06:18 AM
figure8's Avatar
Thanks; I will try the Accel. Looks like it will work fine. Phil
Old 08-15-2004, 11:04 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
i,ve had cars with both and just for ease of maint. i like the hei. just set the timing and go. tune ups are an easy swap cap and rotor and your on your way.
oh and i think the ignition articles are very good theres a lot of good basic info in there. thanks for posting it.
Old 08-16-2004, 12:30 AM
fourbyfourblazer's Avatar
Chopper Builder o<>\o
Last journal entry: Dash Removal
I had points on my blazer. It had the MSD 6A and Blaster 3 Coil. The motor was running rich and wouldn't idle so great. I bought a MSD HEI with 8mm plug wires and now the exhaust doesn't burn the eyes and it starts up on the first crank of the key and idles smooth. My dads been a mechanic going on 40 years and of every thing he's worked on HEI was the least of his problems.
Old 08-16-2004, 08:35 PM
Old enough to know better
About the GM HEI. Ive had a couple of Suburbans that have factory HEI that uses a conventional looking distributor and a remote coil. Standard GM components and rock solid dependable.
It definitly is a much more compact distributor.
Old 08-16-2004, 09:45 PM
docvette's Avatar
Wiki Edits: 12
[color=lightblue]Doc Here
Yup, Points are much cheaper to tune, If you figure $3.50 for a set and 2 bucks for a capacitor, Vs 30 bucks for an ECM...
One thing you CAN say about points...
I have never, ever, heard of anyone stuck 100 miles out in the sticks, ... knee deep in snow ... by the light of the full moon ... Wife and Mother ~in~ Law in the Car Bit*hin' ; "It's Cold, FIX IT you freakin' Clod!" ...and a quadruped Carnivore eyeing your ankels from the woods beyond ... file and re~gap their ECM to limp home......
Plugs and wires are about the same though considering although you never needed the bigger wires, didn't we all buy them?
I don't know , If I had a retro rod, with points in it, and I wasn't racing it, I'd probably leave that way just for grins....
(Besides, what the H*LL else would I do with all these tools?)
However, If I had a highway car with points, HEI would be the first thing to go in..
...Doc [/color]
Old 09-01-2004, 06:31 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Soooo, what are my options for a distributor !!
Old 09-02-2004, 02:05 AM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
HEI,HEI
Points work OK as previous post but lots of maintenance!!! They came out with Dual points (Even in production cars)
to compensate for high rpm points bounce and low voltage of points (points always have to be adjusted for burn), and low coil output to the plugs. Then HEI, eliminated having to change points!! set timing unless messed with!! I use Chev HEI in all my cars to this day. Unless I fiqure the engine will be turning over 5500 rpm, where it will start to break down, If over 5500 I use the MSD with the 6AL box. Most cars down't go over 5500. HEI is one wire hook up and 1 wire tach. Only problem is the bulk if close to firewall or using Dual carb manifold. The HEI dist is cheap!! under $150.00 new full ready to go.
Old 09-02-2004, 08:05 PM
friend's Avatar
New Member
Hi, Just wanted to add...I had to pound my firewall in a little on my 1970 GMC pickup for the HEI to fit. It's just a work truck so It didn't matter. But I'll never run points again after having the HEI in it. Thanks, John
