polish to remove haze? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2009, 03:42 PM
Yesterday I painted my hood with the kirker single stage (cheap, like me) omaha orange on a steel cowl hood for my nova. I had forgot to open my valve before my astro filter in my air line when I went to start spraying, and got large droplets at the front of the hood. I finished anyways and figured I would try and wet sand them out.
Today I started with 400dry, then went to 1500 wet. Turned out pretty good, then wet sanded half of the hood, and then used 3m heavy duty rubbing compound on a soft foam pad.
The side I wetsanded and polished has a much better gloss, but seems almost like it has a milky appearance to it, and not as deep of an orange as the untouched side.
I went to a local auto parts store that sells autobody paints/supplies and when I asked for buffing compound he showed me the 3m heavy duty rubbing compound that I bought.
So..... to the point. Is there another step to get rid of that milkly look?
thanks in advace
Old 09-25-2009, 11:08 PM
Buffer
I hope your using a buffer I buffed my tahoe out with miguars product mild cut the a polish and then wax you can call there 1800 number and a miguriars rep will tell you wehat you need but the main difference is the the pads on the buffer. It should come back I would think so Oh and the buffer I bought was from harbor freight and works great first thing throw the pads away it came with and get some good miguriars pads. Hope this helps Scott
Old 09-26-2009, 11:04 AM
There are probably still scratches affecting the gloss level and giving it a dull apperance. 3m superduty compound is pretty agressive and you need to go over again with finer polishes and pads to remove the compounding scratches. superduty compound alone will for sure leave a hazy look.
But first you need to remove all the scratches in one step before moving to the next or it will do you know good.
400 dry is way agressive for colorsanding. I probably wouldn't go that course, unless I were planning on repainting.
Surprised you didn't go through, and don't believe you could remove those scratches by stepping right to 1500 wet. The most agressive I've ever gone is 600 wet when I have a nasty run, and then step down going over a bit with 1000 till all the 600 scratches are removed and then over again with 1500 before compounding, Even though super duty and a wool pad could possibly remove 600 I believe, its very difficult.
I think you need to go back and try sanding more working on removing you sanding scratches and hope you don't go through, and work down finer, and maybe start out with a wool pad with the superduty (even though I prefer foam pads as they leave less swirls to clean up and aren't quite as dangerous on edges, wool cuts quicker)
Once you are sure you have removed all your wetsanding scratches in the compounding stage (work about 1ftx1ft area at a time), then you should step down to a foam pad and finer cut polish and glazes.
To be put simpily, polishing a vehicle, is a process of putting in smaller scratches to remove larger ones. And you can't take too big of a step in grit-cut in either the sanding or polishing steps.
The better you remove the larger scratches and the finer you get your final scratch, the better the gloss level will be. But on fresh paint, you want to make sure you use paint safe products, as you want the new paint to be able to breath and all those solvents out that still need to escape. Here is a nice chart I just found.http://thedetailinghandbook.com/Polish_Chart.aspx
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Chrome Polish 54 Chevy Body - Exterior 3 05-05-2009 06:13 PM
Remove & Install with or without transmission on {typical RWD V-8?} Rob Keller Hotrodders' Lounge 16 02-17-2006 04:42 AM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 05:01 AM
Recommended Glass Polish?? CHEV66JB Body - Exterior 2 05-20-2003 07:54 AM
