polished firewall - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 09:14 PM
polished firewall
I'm interested in making a firewall for my deuce. Are you guys using aluminum or stainless? How thick? and how do you fasten it? Help would be appreciated along with pics. Thanks
Old 10-12-2010, 12:22 AM
327NUT's Avatar
If I was going to do that....which I wouldn't (to each his own though) I would use polished SS. It will cost more to buy and polish but it won't corrode like alum. You could spot weld through bolts on the back prior to polishing, use pop rivets, button head bolts, machine screws or a a VERY GOOD adhesive
Old 10-12-2010, 11:08 AM
35terraplane's Avatar
Polished firewall
I used S.S., you can buy it already polished. I used it on my Terraplane, it had a funky looking firewall, and a million holes so I put some insulation between them, and I screwed it on with small countersunk heads on machine screws, around the outside edges. I knew there would be things on the middle part of firewall so I used them to hold S.S. tight.
On a 32 you have a pretty flat firewall but if you have to bend it, I just used a metal siding bender, the panel I had was a little to big for it thickness wise but I just wanted it to hold the panel and I bent it with my hands.
sorry don't have any pictures , but it is still as shiny as the day we put it on.
35terraplane
Old 10-12-2010, 01:20 PM
thanks for the replies. I'll keep it in mind.
Old 10-12-2010, 10:03 PM
stea's Avatar
i used polished stainless on mine 5-6 years ago. made a pattern from poster paper and had the local supplier cut it out. I used double stick tape that is used to attach stainless rocker trim. with that and a few parts that do go thru the wall its on there tight.
http://www.hotrodders.com/gallery/sh...hp/photo/22379
Old 10-13-2010, 09:30 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
A great look, I have it on my 34, an added benefit is that it reflects the light into the engine bay, makes the engine stand out by reflecting the backside of the engine, stea's photo shows what I mean.
Another little goody is that going down the highway and the sun at the right angle it zings objects. It is also very easy to keep clean and shined, do not even consider aluminum that would be a huge mistake, SS is hands down the best option.
http://www.hotrodders.com/forum/jour...07&action=view
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
smoothing firewall 71corvette Body - Exterior 6 01-19-2008 08:54 AM
32 Ford Firewall deere Body - Exterior 4 11-10-2006 08:57 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
47-53 Chevy Truck firewall bg Body - Exterior 4 12-31-2004 09:42 PM
