I've been sanding down my intake over the past few weeks and today had my first shot at using the buffing/polishing compounds and wheels I got from Eastwood. What a disaster. I hope someone can tell me from these pictures what I'm doing wrong.
Problem #1 I started with a 4" spiral sewn buffing wheel mounted on a drill (approx 1300 RPM at max speed). To test things out I began by touching the spinning wheel to a brick of 220 compound to load it up. The buffing wheel immediately began to disintegrate with fluff and string flying all over the place. I expected a "bit" of lint (as per the directions) but as you can see from the picture it tore things up pretty bad. The second problem, as seen in the picture, is that since the wheel is sewn in a spiral and since the material in the wheel furthest from the stitching lets go first, the wheel immediately goes out of round and the compound only adheres to the sections nearest the stitching which hold together the tightest. You can see in the first picture the green compound on the right and nothing on the left. It doesn't show in the picture but the green section where the compound stuck is right down by the stitching.
Problem #2 I then decided to give on the wheel for the moment test one of the felt bobs. I also decided that possibly the problem was with the 220 compound so switched to Tripoli compound. I applied the compound to the spinning bob in what appeared to be fairly uniform coverage. When I began to polish the manifold with the bob getting the results shown in the next picture below. A gob of black, hard, tar quickly formed and I could only get it off using 80 grit sandpaper. The third picture shows the bob itself after my attempted use.
I tried a couple additional experiments with the felt bob - running at faster speeds in my die grinder, running with more/less compound, and applying less/more pressure on the bob as I buffed. The only difference was that in some cases I could produce slightly less of the hard black tar on the manifold. But in all cases, it just made a huge mess of my nicely sanded manifold.
Obviously I'm doing something very very wrong and hopefully someone can steer me onto the straight and narrow.
I feel your pain on this one. I went through pretty much the same thing one time. I got so pissed I tossed the intake aside and bought one that was already polished. Eventual I used the screwed up one on a 4x4 crawler that I didn’t give a rats what it looked like. Its no wonder they say polishing is an art. I am surely no artist. Hopefully you get some good replies on this post. I am interested in learning anything I can on polishing techniques
Twisted, in talking to cboy about this intake (and seeing the truck before in person), simply replacing it with a pre-polished one is no option. It's not a SBC, so this is definately a DIY project. Big block Ford "glitz" parts just aren't being marketed. I'm not trying to sound bullish with you, so please don't take my comments too hard. Sometimes you just have no choice but to make due with what you have.
Dewey, Is it possible that the fairly low speed of 1,300 RPM for a buffer be too slow? I think Eastwood or H.F. have bench buffers that spin at around 3,200 RPM. Also, you had it mounted to the shank in the right direction to not "cut against the grain", so to speak, did you.
I got nothing more for you on the first pic, but I have got a thought on the second one. Is it possible that there is a chemical reaction ocurring between the felt bob-the compound- and the intake steel? Just a hunch, but any of those could aso not blend with any cleaner/degreaser you may have used as well. It would seem to me that the tar would not typically for without some form of chemical catalist.
That occurred to me as well so after sanding off the "tar" shown in the picture I put the felt bob on my die grinder (variable to 25,000 rpm) and tried running at different speeds...but got pretty much the same nasty result.
Also, you had it (the wheel) mounted to the shank in the right direction to not "cut against the grain"
Whoa, I had no idea there was a "forward" and a "backward" - and nothing about it in the little buffing manual I got from Eastwood with the kit. I just mounted the wheel on the arbor and went at it. I can try another wheel tomorrow and mount it the opposite way. So you might be onto something here.
... but I have got a thought on the second one. Is it possible that there is a chemical reaction ocurring between the felt bob-the compound- and the intake steel? Just a hunch, but any of those could also not blend with any cleaner/degreaser you may have used as well. It would seem to me that the tar would not typically form without some form of chemical catalist.
My take is that the "tar" is the typical black residue you always get when you use a wax or polish on anything aluminum...only multiplied about 100 times over for some reason... and then quickly hardening. There IS a notation I saw somewhere that if the buffer produces black residue you are using too much compound. But that notation also said to just keep buffing and moving the buffer around to "use up" and dilute the compound. When I tried to do that it just seemed to turn the the goo harder and harder. Also, regarding the cleaner/degreaser chemical reaction, the intake was first degreased with gunk and then run through my sandblaster, ground smooth with carbide burrs and then hand sanded with 50, 100, 180, and 320 grit paper. I can't imagine there being much of any cleaner/degreaser left. I also doubt there is any sort of incompatibility between the felt bob and the compound since both were included as part of the Eastwoods buffing and polishing kits I bought. I tend to think it has something to do with "human error" (uh, that would be MY human error) and not the materials or equipment.
One other possibility might have to do with my shop temperature. I had the heat set at 63 while I was working but it had been much cooler in there overnight so the compound bricks were probably 45-55 degrees.
looks like too much pressure is creating the black tar look..Just a thought..
Start with a coarse compound and then a medium then the fine..about like 600 grit 1200/1500 grit then a 2000 then the polish..Don't worry you will get there.
I just got done polishing a 6-71 blower and a radiator, im sure I did it all wrong but heres what worked for me, don't laugh
Those little wheels are useless
Use the cones on a die grinder, I had 2 compounds from eastwood for aluminum. Go over everything with the coursest compound, get it black, covered in black, hey that way you know what you have done.
Use WD-40 to remove all the black
Go over everything again with a new cone and the lighter compound, make everything black again, WD-40 again (never use brake cleaner)
Go over everything by hand with a good polish, I like Bushe but its really had to find.
I recall having the same problem while polishing a manifold for my wifes car. The black stuff kept building up during the initial polishing. It seemed like it would stick in the sanding scratches then get real thick and hard. I kept cleaning it off with lacquer thinner and continued buffing and the problem seemed to get better. I also found if I worked a larger area it didn't build up so fast. I didn't have much luck with the little bobs so I ended up using small cotton wheels. After that experience I gave up on polishing. Now I just sandblast or paint.
Hi Chet, hey I am so sorry if that is what was thought I was telling him to do. And Trust me I know all about making something due. I merely meant that is what I did. I lost my cool and was in a hurry on that project, I had no choice but to ditch the intake and get one that was all ready pretty. I am all for his completing the project and as I said looking forward to everyone’s input. Someday I would like to tackle some of my own stuff again. Again, very sorry….Troy
First let me say I'm no expert, I have polished several sets of aluminum mags and have learned a bit first hand.
First thing I see is that the intake is still too rough to be polished using the compounds you have. I usually wet sand to 1200 grit, this leaves the aluminum almost there, then go to Tripoli then white rouge, then a final polish by hand with Mother's aluminum polish.
Being that the intake is rough the compound is loading in the scratches instead of cutting the metal, creating a lot of heat and with the friction is making your black goo you can't cut.
Being that it is an intake with all of those nooks and crannys I would get some of Eastwood's greaseless ccompounds in say 220 and 320 grit (part #'s 13131, 13132) and cut with them first, that should really smooth it up being that compounds cut lighter than the same grit sandpaper, then go to the Tripoli and up.
The wheel coming apart is typical from what I have used and will quit shedding material and even up with a short amount of use.
Don't give up, it is a lot of work but once you learn the best method for you it can go pretty quick. Just remember that the metal almost needs to look almost polished before you start polishing, anything less and you will see nothing but polished sanding marks which don't look good at all!
Hey no problem Troy. It's soo hard to get the whole "idea and attitude thing" right when typing responses over the internet. I got into deep do-do with Hippie a while ago the same way I just did with you. I'm sorry as well. It's all good on this end. So, are we still cool?
Well, from the jist of what I'm gleaning from LanceM, DUKEOFBLUZ and your own comments especially....
, maybe the issue is the manifold just wasn't ground smooth enough initially and the black tar is just the result of a bit too much compound and too rough of a basic working surface.
This is just a hunch, particularly with me having exactly zero eperience with buffing or polishing. But, if it works out for you, I'l learn to do it right at the expense of your buffing wheels.... LOL!
Oh no way, you are so on my **** list now forever. Lol . Just kidding.
Of course man, hey **** happens. You said it exactly right. With only words to look at, sometimes actual interpretation is misunderstood.
Thanks for the input so far. I'm taking the afternoon off to watch the 400 - but Monday I'll do some more experimentation with all your ideas. Any additional ideas would be welcome.
Things still not going very smoothly but here are the results of my further experimentation.
1) I reversed the sewn spiral disk as suggested by Chet and it did seem to improve the way the disk loaded up the compound and reduce the disintegration effect. On the minus side, the actual application of the compound to the manifold still produced a very uneven effect with the compound still clumping and leaving black tar like residue. I tried LanceM's suggestion that I first "cut" the surface with greaseless compound. I tried 220 grit (which had almost no visible result) and then tried 80 grit just to see if I could make any sort of visible progress. The brick of 80 grit was much softer in texture than the other bricks and as a result the buffer really slung a lot of residue all over the walls, me, and the manifold. The problem with that was that these little drops and particles of residue leave a stain on the sanded aluminum. I could not find any cleaning solution that would take out the stains and ended up having to sand them all out again. Oh, and the 80 grit where I was polishing just loaded up with black gunk and left a very uneven effect on the aluminum. I quickly gave up on that route.
2) Following Dukeofbluz's suggestion I switched from the small wheel buffer to a cone buffer as shown in the following picture. Duke, is this the way the cone usually looks after a bit of use? As you can see it quickly loads up with the black aluminum residue.
3) Following LanceM's observation that the manifold was still too rough and needed additional sanding, I tested one runner on the manifold by hand sanding from 320 to 400 to 600 and then 1200. I then attempted to apply Tripoli compound with a cone buffer mounted on a drill. I'm including a picture of the Tripoli brick to see if it might give some clue as to what I am doing wrong and then a picture of the result. A huge black tar "skid mark" left on the runner.
4) I then tried Dukeofbluz's tar removal method using wd40. I found this to not work for me at all. First, the wd40 had no effect on the tar and worse, the oil residue from the kerosene in the wd40 left a residue on the aluminum that kept kicking up as I proceeded with further sanding/polishing. Duke must get this to work somehow- but it was a minor disaster for me.
5) Next I just scratched away at the tar with a fingernail and when I got most of it off I resanded the area back to 1200 grit and then tried the cone/tripoli once again being very careful to stop polishing as soon as I saw any black build up and immediately scraping it off by hand. Then polishing a bit more...then scraping off any residue. It is a fairly slow and tedious process (and doesn't seem at all correct according to everything I have read about polishing) but here is the result on the experimental runner (the one n the foreground).
6) The above pics were actually taken after not only the tripoli polish but a going over with rouge which was applied with a felt bob. I am attaching a pic of the bob after the application to see if this is the way it ought to look (blackened).
While I can see a bit of improvement here in terms of the results, I'm still miffed about the process and am quite certain either there is something amiss with the compounds I got from Eastwood or (the much more likely conclusion) I am still doing something quite wrong with the technique(s) I am using.
I showed Dawn your pictures and she says that when she played handbells and they polished them their polishing clothes always turned black. So, the black on the felt bob is probably a good thing.
Cboy, I am certainly no expert on polishing but I recently polished a set of aluminum wheels and a FI manifold for a 5.0 and although I used the same procedure you started out with (Except I used a much higher speed to begin with) I did not have the problems you have run into. The main difference I see is I used the compound sticks sold at Sears so maybe you are on to something with the idea that maybe it is the compound you are using. It would cost very little to try the compound from Sears, it worked really good for me. Just a thought.
Chet: I'm going to hobble along with the "new" system but it sure is time consuming. So I'm still looking for any improvements I can make. Regarding the black residue, I think you are correct that it is to be expected. I know I always get it when I shine up my wheels with Mothers polish. It just seems I'm producing WAY too much of it on this manifold and that, unlike my wheels, the stuff is then turning into a tar like substance that gets so sticky or hard that it can no longer be buffed.
Oldred: Next time I'm at Sears I'll definitely pick up some of their compounds, or maybe I'll check my local CarQuest to see if they have any. The stuff I have seems to me to be pretty hard,dried out and even flaky, except for the 80 grit which was just the opposite, too soft and runny. But then what do I know. I really wish I could witness how it was SUPPOSED to look and act. Maybe that's the way one of you accomplished polishers can make your fortune...by producing a video showing all the ins and outs. I'm interested in you comments on buffer speed as well. The "machines" I have seem to be on the extreme ends of things, either a variable speed drill which runs at a relatively slow 1250 (max), my electric long shaft die grinder which runs a constant 25,000 or my air powered die grinder which supposedly is variable speed but is almost impossible to hold at any consistent speed other than it's 20,000 max (although as I think on it now, maybe I could rig up a couple of "stops" on the trigger to get it in the 3,000 - 5,000 rpm range). I do have a variable speed Dremel which would work great...but it will only drive 1/8" tools so will only be of use to get the little nooks and crannies. As a result, I seem to be stuck running either very slow speeds or very high speeds...which could be contributing to my problems.
Hard dried out and flaky is the tip I needed..the compound needs to be wet so it does not dry out when buffing and make that hard tar deal..How wet will it will take a bit of experimentation to get it right...the black is just part of the deal..your buffs will turn black from the tiny particles coming off of the part..
Cboy you have really hit something I've never seen, and with everything you have tried you should have had much better sucess than you have. I would really start to wonder about the compounds now, you should have left your problems behind by now with one of the techniques posted here that you have tried. I'm stumped as to what to tell you now, when you figure it out let us know as we are bound to run into it ourselves one of these days!
I used the small cones like the second one you used, and a very small one on a dremel for the tight areas.
As for the WD-40, I just sprayed it on , let it soak a minute or two then used a couple rags to wipe everything off, at that time it still it still looks like crap. When im all done I go over everything by had with a good polish, then everything looks great.
Cboy, This might be a little late although I am not a polishing expert either but I polished a couple wheels at work this past weekend and to get that black stuff off my boss had me take some laquer thinner to it and it worked real good. Hope that helps you
CBOY
It seem to me that your compounds are TOO DRY! & your wheels too fast.
Try getting new stuff from a paint & body Supply house not the auto parts store ,because they don't sell as much there for it seems to dry out {sitting on a shelf for how many years?}
The black is gonna happen .
I've been detailing stuff for 20+ years a GOOD metal polish will help in cleaning up the "Black Nasty's"
also rotate your cleaning rags when removing the "Black Nasty's" it seems to come off better in lower humidity like letting wax flash.
I'm no Expert @ polishing {yet " its on one of my to do lists"} but I have had to do some and this is hands down the best line of products for this type of work I have come across.
Rob, About that speed, 18,000 RPM is what I used with the smaller wheels and cone shaped buffs and 1200 RPM with the 8" wheels. Not that I think this is the right RPM it is just what the tools I had would do. I never had the problems that Cboy had but I did wonder if I would have been better off with a variable speed tool. What about the 18,000 for the buffs is that too fast? what about 1200 for the 8" wheels, maybe too slow? That Sears compound seems to work really good but then it is the only compound I have tried. It is sealed in blister packs and seems not to be dried out and loads fine on the wheel without flaking or crumbling. Any recommendations on a good buffing tool? I mostly intend to buff out another set of wheels and some aluminum cases (alternator, air conditioner compressor ,etc)
I got an Aluminum MB 240D 2.4L 4cyl diesel valve cover that I tried polishing, I bought brown tripollie and white compound, and it has no effect, I did the air cleaner cover just fine with the same products, the old wheel was black and dingey, and glazed over, so I bought a new 1 and have yet to try it, it is 4" spiral sewn.
Like i said I haven't gotten to do this yet I'm just using what comes to mind seeing the pictures .
My polish/sander for boats & cars I believe runs relatively
slow I have to go look @ the machine tomorrow but I want to say 1725 to 2400 Its a variable speed Makita.
From what I have read in Rcastles Post is that the grease less compounds are the cats meow.
So Please excuse my ignorance here but I'm under the impression to sand ,sand ,sand,. . . then a slow polish because the picture tells me that its getting way too hot too fast .
Now maybe{just maybe} I have used a product that is a lube for wet sanding & claying{over spray on paint removal}
It could just need some water/ soapy water, some kind of lube to loosen it up just a little.
A lot of times I will water down compound just a little to get it from paste to semi paste.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
