Polishing aluminum grill help
I have two aluminum grills that I am trying to polish. I picked up the second because mine was badly damaged and the other was near perfect and only $50. also the second has Dennis Carpenter reproduction headlight doors. Here is my problem, I striped the anodizing off headlight doors with a powder and water solution I bought from the auto fair. I decrumpled and pounded straight the originals, I thought this was going to be the hardest part but with a little time they are near perfect (I was going to throw them in the trash). The originals I started with 120 grit and the re pros 320 grit sand paper in 100 increments and ended with 600 grit. Now to the polish, I used a black emery on a sown cotton wheel on the end of my 4" angle grinder (10,000 rpm) it is starting to shine. Next I use the red rouge on a new cotton wheel its getting dull? Maybe ill try the white and it will be like new again? Didn't happen. The only compound I am getting a shine with is the black emery and a good shine but I still have alot of fine scratches in the surface. I tried using a sander I have that spins at 4700 rpm thinking maybe I was losing all the compound from the wheel but I get no shine at all with it. Also the re pro doors are getting almost no shine as opposed to the originals came to a shine pretty quick. What am I doing wrong?
Might try Mothers alum. polish and the power ball polisher sold at your local parts store.
i have even gone to the local truck wash like BLUE BEACON when they are slow on business and have them fire it up with aluminum brightener. They use it on fuel tanks and rims on the semi's and usualy makes a good shine. Once you remove the protective coating on aluminum they are susceptible to corrosion and will turn dull in a short time from road grime and salt solution from the winter time when they spray their salt and beet juice all over the road. hope this helps!
Here's a good site for polishing ? Lots of info here!! They have a forum, too!
http://www.caswellplating.com/buffs/buffman.htm Last edited by evolvo; 06-17-2010 at 11:26 AM. |
| Aluminum Welding - Weld Prep | Joelk | Body - Exterior | 10 | 05-22-2010 05:51 PM |
| Aluminum polish? | 66 Restomod | Body - Exterior | 24 | 10-04-2009 02:17 AM |
| Aluminum polishing tips wanted. | Full Throttle | Engine | 6 | 12-17-2004 08:11 PM |
| polishing aluminum | hvyeqpmech | General Rodding Tech | 5 | 07-06-2003 01:08 AM |
| polishing aluminum wheels | 65galaxie500 | General Rodding Tech | 7 | 02-10-2003 07:34 AM |
