polishing new paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 09:08 AM
polishing new paint
I had a single stage paint job done and a month later decided to polish it with a buffer (first time) and Meguiars dual action cleaner polisher.
I put it on with the buffer (wool pad) and wiped it off by hand. At first the result looked fine, but later I realized there was a blotchy, cloud like mist look all over.
I couldn't polish it off by hand so I used wax remover which left a slight film. Then I used a cleaner type wax (by hand) to redo all.
It came out very nicely, until the sun hit it, then a horde of ghost like graffitti buffer lines made an unwanted appearance.
Looks lame!
Not happy!
Have I ruined my paint or is there a solution for my stupidity
Old 08-13-2012, 10:21 AM
cyclopsblown34's Avatar
Colorsanding painter
Try a foam pad on the polisher with some swirl remover. I use Meguiars. Do it all in the shade and wax it pretty good in the shade after the swirl remover. Pull it out in the sun to check the finish and make certain it's as you wish it to be.
Old 08-13-2012, 02:21 PM
Thanks. Are ther foam pads and then there are foam pads?
Old 08-13-2012, 02:48 PM
I'm thinking you should be able to get Meguiars or 3M foam pads where you got your polisher.
Old 08-13-2012, 04:58 PM
Yes they do. I have a blue pad and don't know what grit(?) so before I possibly made another poor decision I went back, used my wax remover, washed with hot water and soap and applied the previously used cleaner/polisher, hand rub on, wax. This time I rubbed on by hand and machine buffed off but eventually my pad took on too much polish and I had to finish all by hand.
I took it out in the sun and voila (?) 98% of graffitti (?) was gone!
Thanks for your advise. I will try to find out how, first, next time. Dogs have come back home again!
Polishing Imron 5000 paint? makaveli200369 Body - Exterior 4 10-28-2009 06:35 AM
Ok to use polishing compound on metallic paint? tcruise Body - Exterior 3 11-14-2005 03:30 PM
Polishing EazyDuzIt102 Body - Exterior 6 11-11-2005 10:50 PM
Buffing And Polishing New Paint. richamer1 Body - Exterior 2 10-11-2005 08:51 AM
Glazing, Polishing, Compounding After New Paint! Help! Torx Body - Exterior 9 08-12-2004 07:37 PM
