-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Polishing Plastic Gauge Faceplate (http://www.hotrodders.com/forum/polishing-plastic-gauge-faceplate-78160.html)
swamprattler 01-07-2006 03:30 PM
Hi
I was wondering if anyone has had any experience with trying to polish the plastic clear face plate that goes over the gauges. These face plates tend to get very fine scratches and after 56 years in a car they become hazy. If you have had success with this please explain what you used and how you went about it.
Thanks
Rob Keller 01-07-2006 03:52 PM
1 Attachment(s)
YesSir orM'am
this is the answer
http://www.flitz.com/products.html
go to products~application suggestion~before & after photos good poop been using all these products for years best thing is it cleans & protects like never dull on brass but wont smudge as bad (example)
SR66 :thumbup:
BOBCRMAN@aol.com 01-07-2006 04:04 PM
When I was re-conditioning industrial equipment. I used fine polishing compounds then sprayed faces with non-yellowing, high quality clear paints.
coldknock 01-07-2006 04:17 PM
Meguiars Plast-X worked pretty good on the gauge cover in my Nova.
Larry
swamprattler 01-11-2006 03:16 PM
Thanks for the help. I tried the Mequires Plast-X (got locally) and it worked great, this product does what it says it will do.
1ownerT 01-11-2006 05:14 PM
I have had great results removing deep scratches from gauge covers by wet sanding then polishing.
302 Z28 01-11-2006 08:48 PM
Mequires has great products.
Vince
Henry Highrise 01-11-2006 09:12 PM
Fine MirrorGlaze works good too.
FlatheadStude 01-13-2006 05:28 AM
MOdel car wax
Go to a Hobby shop...they have a kit with varying degrees of sand paper that will polish scatches out of model car windhields..Novas I think is the name..but not sure...works great...
1streetrod4u 01-13-2006 07:43 AM
How to polish your plastic guages!
Hi, I have used a Headlight polishing kit from eastwood for gauge plastics. Here is a link to Eastwood's site! Hope this helps!
Ivan
http://www.eastwood.com/shopping/pro...Plastic+polish
dankarol 01-13-2006 03:02 PM
face plate wax
When I worked at a paper mill we used Johnson liquid floor wax on out plastic face shields to take out the scratches and it worked ok, but if you have deep scratches I doubt anything will help to take them out. Hope this helps. Dan
danny t 01-19-2006 09:40 PM
polishing gauge faceplates the minty fresh way
Try toothpaste it actually is a VERY mild abrasive. I used
to use it on my plastic models. :mwink:
Rob Keller 01-19-2006 11:08 PM
3-M makes a head light fixit up for the plastic composite lights I here it works good .
All my head lamps are covered in good old glass
:thumbup:
vorgath 02-25-2006 06:07 AM
:D Toothpaste .. now that brings back some memories, when one didn't have all the polishing products around, I was taught by my ma and grandma, use toothpaste to clean silverware.
It does really work, so yeah shoot for that, use some glaze after that and finish with hmmm wax or something cleaning wax maybe ?
I got an extra gauge cover myself, will try to remember to take some pics of the process
