Polishing Plastic Gauge Faceplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2006, 02:30 PM
Hi
I was wondering if anyone has had any experience with trying to polish the plastic clear face plate that goes over the gauges. These face plates tend to get very fine scratches and after 56 years in a car they become hazy. If you have had success with this please explain what you used and how you went about it.
Thanks
Old 01-07-2006, 02:52 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
YesSir orM'am
this is the answer
http://www.flitz.com/products.html
go to products~application suggestion~before & after photos good poop been using all these products for years best thing is it cleans & protects like never dull on brass but wont smudge as bad (example)
SR66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 01-07-2006, 03:04 PM
BOBCRMAN@aol.com's Avatar
When I was re-conditioning industrial equipment. I used fine polishing compounds then sprayed faces with non-yellowing, high quality clear paints.
Old 01-07-2006, 03:17 PM
coldknock's Avatar
Meguiars Plast-X worked pretty good on the gauge cover in my Nova.
Larry
Old 01-11-2006, 02:16 PM
Thanks for the help. I tried the Mequires Plast-X (got locally) and it worked great, this product does what it says it will do.
Old 01-11-2006, 04:14 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have had great results removing deep scratches from gauge covers by wet sanding then polishing.
Old 01-11-2006, 07:48 PM
302 Z28's Avatar
Mequires has great products.
Vince
Old 01-11-2006, 08:12 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Fine MirrorGlaze works good too.
Old 01-13-2006, 04:28 AM
Last journal entry: NOway
MOdel car wax
Go to a Hobby shop...they have a kit with varying degrees of sand paper that will polish scatches out of model car windhields..Novas I think is the name..but not sure...works great...
Old 01-13-2006, 06:43 AM
HOT RODS!!! I Like it all !!
How to polish your plastic guages!
Hi, I have used a Headlight polishing kit from eastwood for gauge plastics. Here is a link to Eastwood's site! Hope this helps!
Ivan
http://www.eastwood.com/shopping/pro...Plastic+polish
Old 01-13-2006, 02:02 PM
dankarol's Avatar
40 nash
face plate wax
When I worked at a paper mill we used Johnson liquid floor wax on out plastic face shields to take out the scratches and it worked ok, but if you have deep scratches I doubt anything will help to take them out. Hope this helps. Dan
Old 01-19-2006, 08:40 PM
polishing gauge faceplates the minty fresh way
Try toothpaste it actually is a VERY mild abrasive. I used
to use it on my plastic models.
Old 01-19-2006, 10:08 PM
Rob Keller's Avatar
Wiki Edits: 38
3-M makes a head light fixit up for the plastic composite lights I here it works good .
All my head lamps are covered in good old glass
"SlowRide66"
Old 02-25-2006, 05:07 AM
vorgath's Avatar
Toothpaste .. now that brings back some memories, when one didn't have all the polishing products around, I was taught by my ma and grandma, use toothpaste to clean silverware.
It does really work, so yeah shoot for that, use some glaze after that and finish with hmmm wax or something cleaning wax maybe ?
I got an extra gauge cover myself, will try to remember to take some pics of the process
polishing plastic lenses Jag Daddy Body - Exterior 8 12-12-2005 12:26 PM
mechanical oil gauge bleeding? cboy Engine 5 06-28-2005 04:37 PM
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 11:46 AM
Autometer gauge faceplate modification McDeuce Electrical 4 03-22-2004 01:18 AM
Twilight Zone and my temperature gauge unstable Engine 8 10-08-2003 03:57 PM
