Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Polishing spi universal
Old 02-15-2013, 07:07 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
Originally Posted by lukeembry View Post
What are you using to finish buff on your spi universal? I have mine cut and polished but not getting the shine I'd like to see. This is on red that is flat as glass and cut well just looking for ideas on steps and compounds after the cutting process.
The one time I had that problem it was because I put more than two coats on at once (4 coats) and tried to buff it too soon....It hadnt cured completely even though it was two weeks later,Plus it was cold when I painted...it took almost two months before I could buff and polish it properly...
Now days I spray two coats and only two coats ,if I want more clear I spray two more coats after two days...and after sanding with 600-800 (of coarse)...to check to see if the clear is cured enough I press my finger nail into the clear to see if it leaves an indentation,if it does ,its not ready....
