Polishing Torq Thrust II's - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 08:25 AM
sicksixseven's Avatar
Ground Clearance Is Over-Rated
Hey guys, I recently pulled my Chevelle out of the garage from a long winter, and noticed that my rims were pretty dirty, and my exhaust tips were a little rusty. I use Eagle One NevRDull on them, and the tips came out like mirrors, but the wheels just arnt polishing. I did my best, I was outside doing it for litterally 3 hours, and it still looked like there were spots on my wheels. These things are less then a year old, and have never been drivin in inclimate weather. I am just nervous that these are stained. Is there any techniques that anyone has tried, or has anyone even experienced anyhting like this? Thanks for the help.
Old 03-13-2006, 10:01 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
FYI American wheel has a polish in a can that kind of reminds me of NEVER Dull, however it is by no means the same product. I have used this for the past 2 years and it works very well. The spots could be stains, with that in mind I think I would use the manufacturer's suggested product to try and remove unwanted stains and marks. The secret to polishing alum wheels is easy on the pressure, so as not to add scratches to the mirror finish. Another good product for these wheels is Eagle One, get the PH balanced . Water will also spot alum. The method for cleaning your wheels should go like this. Cold wheels, first wash them with the Eagle One product and then polish the rims. Apply the polish and let it haze before buffing ( hand buffing )
Hope this gives you some insight .
Old 03-13-2006, 04:43 PM
I here the mothers powerball is the only way to go. Letting your cordless drill to the work. Has anybody tried one of these.
Aaron
Old 03-14-2006, 09:04 PM
gmwillys
polishing torq thrust II's
While at the boat show a couple of weeks ago, I bought a product called Prism polish. I believe it was designed to be a deoxidizer for fiberglass boats, but was also good for metal. Its fantastic! I couldn't believe how well it worked on aluminum. It reminded me of mother's, but with half the effort.
Old 03-15-2006, 10:31 AM
I know from experience that you can't get those stains out by hand. I have a set of those wheels.
There are two ways to polish the wheels that makes it very easy. The first is the Mothers Powerball, which works well for the price. I use that along with the mag and aluminum polish.
The second and better method is with the flitz power wheel. It's a more robust polishing ball and really can bring out the shine. It's also more expensive, but works faster still.
With either of these methods all your wheels will look much, much better after about 1/2 hour.
Old 03-15-2006, 04:20 PM
McDuff's Avatar
StreetRods Rock
I have tried the "abrasive" cleaners on my aluminum wheels with success, but I recently tried a "chemical" cleaner with greater success. I bought it from Adam's Polishes and there are two levels of cleaner. I didn't rub hard like in the past. Google his website and he has videos explaining all of the products. It is a great website with lots of information. I emailed him and he responded very quickly and with great information. Try it.....you may like it.
Old 03-15-2006, 06:41 PM
302 Z28's Avatar
That is the primary reason when I am ready for my Torq Thrust's, they will be the chrome plated variety.
Vince
Old 03-15-2006, 10:28 PM
McDuff, if you like the chemical cleaners try one of the the power buffs. I think you'll like it so much better you'll sit there and stare at the wheel.
Old 03-16-2006, 07:21 AM
bikertrash92's Avatar
Just used the new "foose ball" this weekend on a set of 4X4 rims that havent been polished or even cleaned for that matter since last fall, that thing is absolutley amazing, a little mothers liquid mag polish and a drill and about 20 min. per wheel and they looked BETTER than new, really they shined like chrome, give it a try, ALOT less work than polishing by hand and well worth the money IMO.
Old 03-16-2006, 11:12 AM
When I've had pretty bad aluminum or chrome I've used Blue Magic. It doesn't smell too good, kind of like ammonia, but it will make aluminum look like chrome, and really bring a sparkle to actual chrome.
Barry
Old 03-16-2006, 11:21 AM
McDuff's Avatar
StreetRods Rock
Hey Biker, I haven't heard of the Foose Ball. Where did you see it and buy it? How much?
Old 03-16-2006, 11:46 AM
I believe the "Foose" ball is the Mothers Powerball.
Old 03-16-2006, 12:32 PM
about the same thing, really the powerball is cheaper, the "fooseball" is just made by chip foose and probably just paying for the name, I got it from a buddy for a small welding job is the only reason for having it
I Saw Torque Thrust II's In a movie set in the 50's 67 Deuce 4 Me Hotrodders' Lounge 15 03-16-2006 04:58 PM
How to remove broken screws from torq thrust wheels Ripped Suspension - Brakes - Steering 5 12-29-2005 06:29 PM
Torq Thrust D rip offs 68Velle Hotrodders' Lounge 2 04-07-2005 07:30 PM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Torq Thrust mitmaks Body - Exterior 1 02-15-2003 07:23 PM
