Polly locking nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 02:14 PM
Tonythefish's Avatar
Last journal entry: final pics
Polly locking nuts
With the re-assembly and dissemble process of mocking up my front end , I need to tighten and loosen these Polly locking nuts . Should they all be replaced when I do the final Assembly ?
Old 01-28-2007, 02:49 PM
powerrodsmike's Avatar
Wiki Edits: 161
I usually go to the hardware store and buy some standard nuts to use as mockups. They are cheaper than nylocks and are easier to take on and off during mockup asembly.
If you have run those nylocks on and off more than a couple of times, they need to be relaced with fresh ones. I always do my final assembly with new nylocks and some red loctite on critical assemblies.
Mikey
BE different....ACT normal.
Old 01-28-2007, 07:50 PM
Last journal entry: frame build
Good job Mikey. The only way.
Old 01-31-2007, 11:28 PM
whatwouldscoobydo's Avatar
FAA reg's ,you can reuse nylocks as long as they can't be threaded on by hand
Old 02-02-2007, 06:26 PM
Not saying they don't, because I have never read FAA regs but most heavy equipment manufactures recommend replacing nylocs after every use.
Old 02-02-2007, 06:52 PM
Wiki Edits: 161
In my A&P Mechanics General handbook, (DOT/FAA standard),it calls the locking nut an "elastic stop nut" with a fiber insert.
It does not make any mention of the nylon type. I know the nylon type has no fibers in it. I have seen the fiber type and the insert looks like FRP.
I'd buy new ones.
Mikey
Old 02-02-2007, 08:53 PM
Last journal entry: More on the Cobra Engine
I'm all for useing regular nuts for the fit-up and then only useing the poly-nuts upon final assembly. Besides it's a pain in the shorts to always wind those theads on with a poly nut.
Old 03-09-2007, 11:32 PM
Nylon locking devices are NOT allowed on commercial or military aircraft equipment, lock washers, deformed thread type locking devices, safety wire are OK and avoid locktite if possible, messy in the field and amount used not specified. Nylon "takes a set" and after thermal cycling will eventually come loose. It was a no no at Honeywell, Allied Signal, Boeing, etc. But on auto's, go for it. I don't like to use them on my projects. They do come with many aftermarket parts I buy.
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 12:41 PM
vapor locking Mustangsaly Engine 16 11-03-2005 05:36 PM
Going nuts engine strikingthematch Engine 6 07-22-2004 06:58 AM
4X4 locking hub ID?!? ramjet Transmission - Rearend 7 01-08-2004 05:36 PM
locking lug-nuts on wheels, How to remove? HELP! NASCAR314 Suspension - Brakes - Steering 9 11-15-2002 02:18 PM
