Poly 318? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2011, 12:26 PM
Poly 318?
my uncle recently purchased a 1966 Bellvadere which he was told that it had a poly 318 in it. what makes the differences in this engine? is it in the heads?if it is what?, like the heads off a larger engine or hemi heads?
Old 11-25-2011, 12:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Poly was something of a cost-cutting measure, being as how the Hemi was a complicated bit o' work to manufacture and assemble, plus it made for a wide engine at the top end and was heavy.
To answer these issues, the Poly was introduced. The design actually isn't a bad one, IMHO.
More on it- http://www.allpar.com/mopar/poly.html
Using Poly Primer instead of Poly Putty in between Epoxy and Eurethane primer 67Elcamino Body - Exterior 24 09-21-2011 02:32 PM
Poly Filler vs Poly Primer 67Elcamino Body - Exterior 12 06-29-2011 06:09 AM
318 Poly Engine rough_idle Engine 34 06-04-2010 06:30 AM
I have 318 Poly answers! Abomination Engine 2 01-21-2007 01:34 PM
