poly bushes or rose joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2005, 01:48 PM
blown volvo's Avatar
Ok at the moment iam using poly bushes on my four link.And over the years they look like there have dry-ed out so i was thinking about going over to rose joints.So to the point what pros and con,s between the two have you guys had ????
the car is 75% street 25% drag so i would like a nice street ride more (full tubed no trim) ..On my business partners pro street chevette he has rose joints on four link ..It like driving a tin can with stones in it
Old 10-21-2005, 04:56 PM
My guess is that the reason it feels like a tin can is because the joints are all loose. Solid joints will transmit more vibration into the car then a rubber bushing but I can't see it being much more than a poly bushing if the joints are tight.
You could also go halfway and use poly or rubber on one end of the link and solid joint on the other end.
There are also some nice new rebuild-able spherical bearings out there that should work well on a street driven car (most of them were made originally for 4x4's).
Like these:
http://www.polyperformance.com/shop/...&cat=59&page=1
or these:
http://www.suicidedoors.com/4Link_Pa...k_Bushings.php
Ball Joints....not a hot rod but.... screamin340 Suspension - Brakes - Steering 7 08-05-2005 03:51 PM
how do I remove universal joints Neophyte Transmission - Rearend 11 02-05-2005 11:36 AM
Poly vs. Rubber Bushings? Billy Boy Suspension - Brakes - Steering 6 04-28-2004 05:36 PM
Front end U joints Trav Transmission - Rearend 2 10-06-2003 06:52 PM
Ball Joints Question!!! bg Suspension - Brakes - Steering 2 03-31-2003 06:26 PM
