Poly bushing questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2008, 03:49 PM
Jmark's Avatar
I have a full set of polyurathane control arm bushings for my truck. The rubber ones just don't cut it, keep shifting badly.
I've changed hundreds of bushings over the years but wonder if I can use the same "tricks" on the poly bushings. I usually just remove the nuts, knock out one bushing, slide in the new one, put on washer and nut, tighten some, then air hammer the back side of the arm, tighten more, hammer a little more till it's home. Then do the other side. I"m basically using the control arm and nut as my press. Always worked fine. Can the poly bushings be installed the same? Really hate to have to pull the lower arms all the way out and fight the springs.
Mark
Old 02-19-2008, 03:51 PM
Holder350's Avatar
Auto Parts Professional
YEP! but make sure you use LOTS of the sticky lube they send with em!
Old 02-20-2008, 01:44 PM
Jmark's Avatar
Well, all done. 3 hours, 50 minutes. Had to pull the right lower arm all the way out, stinking headers were in the way. Left lower took about 20 minutes, both uppers in about 20. I really don't like working on the floor either. Miss the days of having access to a hoist.
318 Poly performance/parts/info Abomination Engine 1 11-30-2009 05:29 PM
69 Chev 350 block has a distributor bushing? baddbob Engine 1 06-22-2007 04:22 PM
New Guy, I have info on the 318 Poly! Abomination Introduce Yourself 4 01-21-2007 01:20 PM
Sway Bar bushing blues bowtyebob Suspension - Brakes - Steering 6 11-27-2006 05:58 AM
trans tailshaft bushing fit cboy Transmission - Rearend 8 04-20-2006 09:31 PM
