poly prime gun help
Hi all, I currently have a HF 43430, that I used for my first primer gun. Cut the PCL poly with acetone to spray it . I also have the old purple touchup with the 1.0, wish they still had those. The new chrome one feels cheap. I later bought the startingline set and have been using the 1.8 tip for epoxy and surfacers. I recently started doing more paint work and would like to add a few more guns. Soon a better gun for finish also
I would like to pick up another cheap gun for polly would you rec the TCP pro with 2.0 or 2.5. or the Vader on northern tool with a 2.3 ? Or can I still get a 2.2 or something for the 43430 Thanks Anthony |
Get biggest tip possible for polyester primer.
for PLC a 1.8 is fine but a 2.0 is ideal. With PLC you might get runs with a 2.3 but don't know for sure. Our painter uses a 1.7 but as a body guy I wish he used a 2.0, and anything under 2.0 is pushing it with the acetone. 2.0-2.2 is also good for featherfill.
I have a 2.5 mm cannon I got from TCP Global for around $40. It throws my unreduced Slick Sand on effortlessly, and the quality of the gun was actually pretty impressive too. I was expecting it to feel a lot cheaper than it did.
[QUOTE=Lizer;1631954]I have a 2.5 mm cannon I got from TCP Global for around $40. It throws my unreduced Slick Sand on effortlessly, and the quality of the gun was actually pretty impressive too. I was expecting it to feel a lot cheaper than it did.[/QUOTE
I was looking at their 2.0 or the 2.5. but also the vader 2.3 are the TCP guns real hvlp guns or do they take alot of pressure and make alot of overspray like the HF gun |
Most guns are HVLP nowadays, you won't hardly find any conventional as they're outlawed by EPA...
You do have to turn up pressure to lay out primer smoother, unless you want drywall like texture. |
| suspension rebuild. Poly or not to poly? | Gamecock66 | Suspension - Brakes - Steering | 3 | 05-11-2012 11:22 PM |
| Using Poly Primer instead of Poly Putty in between Epoxy and Eurethane primer | 67Elcamino | Body - Exterior | 24 | 09-21-2011 02:32 PM |
| Poly Filler vs Poly Primer | 67Elcamino | Body - Exterior | 12 | 06-29-2011 06:09 AM |
| low priced spray gun/detail gun for primer/base/clear and ghost flames | jrmy_1 | Body - Exterior | 15 | 06-08-2008 06:38 AM |
| 3.0 Tip Poly Primer Gun | bubjel | Body - Exterior | 3 | 04-25-2008 06:49 PM |
