Poly primer on 72 Skylark - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-29-2009, 06:18 PM
i don't really have a choice unless i mount it right next to my pressure regulator on my gun! My hose is 25ft and is 3/8 as well
  #17 (permalink)
Old 10-07-2009, 05:34 PM
jaak923's Avatar
I haven't had a chance to block it yet, but I picked up a gallon of Mar-hyde's Quicksand, their version of Slicksand and it sprayed a whole lot better than Slicksand did. Like I said I haven't blocked it yet so I don't know how it sands, but as far as spraying goes...Quicksand is better.
I still reduced it 10% like I do with Slicksand.
Jason
  #18 (permalink)
Old 10-09-2009, 03:18 PM
jaak923's Avatar
Jason
Sanded a door today, seems to sand as easy as Slicksand.
Jason
  #19 (permalink)
Old 03-05-2010, 10:10 AM
in poly primer u will always get the gun to spray like if it was dirty,spitting right and not spitting,u can always reduce the polyprimer with acetone no matter how much is reduced it willl still harden thick and ill work alot better ,if u r using the the primer as a flat color like regular primer u can't just buy a flat color.for poly is just to get the body work into a perfect shape you sand the body down with 220 the shoot the primer resand it with 320 and give it 2 more coats of poly them just sand it with 400.then you r ready do shoot your paint..
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
SPI primer and clear, a product review, and a "how not to" lowROLLERchevy Body - Exterior 26 12-21-2006 07:40 PM
PPG K36 primer w/ purple gun BIGSKY Body - Exterior 16 11-20-2006 01:12 PM
Question about factory replacement parts and primer makaveli200369 Body - Exterior 2 05-01-2006 09:40 PM
Question abour factory replacement parts and primer makaveli200369 Body - Exterior 11 04-30-2006 10:24 PM
