Sounds risky to say it is ok...You have doubts or you wouldn't post a question like that. It may feel cured on top but inside there may by pockets under there where no hardener got mixed in at all. Most fillers including 2 part glazing putties should kick in and be ready to sand in 5 minutes. Best to remove and re- apply in this case..
Here's a thread that may help explain the different rates plastic filers sand... http://www.a2zautoforums.com/showthread.php?t=936 Of course there will be some hot dog who says it'll be fine but even you don't trust it.. |
putty
Take the putty off,it was NOT catalized properly,for long term rust protection,spray the car (or panels) with a 2k primer,then putty over the primer.if you sand thru the primer,re-primer it.
Waaaaay back when feather fill first came out..(I was used to lacquer primer) but thats what we used back then... heres what I learned....even if it feels dry it has to come off and its a PITA...but, since you used the hardener it might be ok ,but dry sand it and see if it balls up on the paper ,if it does it has to come off...if it dont and it sands nice its probably ok....You just have ask yourself one question......Do ya feel lucky? Needless to say, I had my fill and never used that stuff again,it sanded like a brick anyways and theres much better primers out there anyways ...I tried slick sand a few years ago its cheap but I hated it ,I stay clear from all those poly primers these days and stick to epoxies and 2k's only...heck I cant see good enough to count those little drops anyways ,4:1 is easy |
I miss read ...if your poly FILLER took 3 days to dry you definetly didnt use enough hardener and it HAS to come off...That stuff drys in minutes....What brand are you using???
waiting a couple days was a mistake too. The first time I did it I waited and I wasn't able to scrape it off/sand it off so easily. The second time I fessed up quickly and it scraped right off then I sanded off the few remaining boogers and reprimed. I'm very conscious of adding primer now so I'll look for the oxygen out gassing right in the cup before I throw it in the gun just to be sure, a little overly sure.
I'm just glad someone else fessed up...when I went and asked my friend that worked at a body shop how long it takes for that feather fill to dry the first thing he said (with a big grin)was did you forget the hardener???? but he never admitted he did it too..... I suspect he did...I think a lot of people did...
| 3M polyester body filler opention | smithkustoms | Body - Exterior | 10 | 05-04-2010 10:54 AM |
| If you dont have dried out salt lakes..... take frozen lake instead. | jimcar-9 | Hotrodders' Lounge | 5 | 05-07-2009 10:52 AM |
| primer not dried? | yasmany | Body - Exterior | 3 | 10-19-2007 08:01 PM |
| sun-dried plastic | LS1 -Volvo | Interior | 17 | 11-07-2006 02:03 PM |
| Question for Polyester spray filler users | misteryu | Body - Exterior | 7 | 10-17-2004 11:21 AM |
