Polyester putty test of sorts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2005, 10:21 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I had this "pallet" that I used awhile back with some Evercoat Easy Sand filler left on and decided to do some "Testing" with it.
It's just gal. sheetmetal cleaned with acetone and has no scratches/sanding done to it.
This is the panel to start with.
This is how far I was able to bend it before cracking occured.
This is an actual piece that cracked off and as you can see, the thinner end,as this was a edge piece that got thicker left to right,is considerably flexable.
As you can see, It did break but only up into the thicker area.
Thought you guy's might be interested.
Old 04-17-2005, 11:34 PM
Last journal entry: metal finish
Hmm.. well i have to say im not very old at all.. 22. however i remember being about 6 years old and messing with pieces of filler that would be left on the floor by my dad.. im not even sure this stuff flexed at all.. just broke into pieces instantly and without effort. today i think even the bondo brand bondo even flexs a little bit.. its a good thing for sure haha
Old 04-18-2005, 06:29 AM
That easy sand finishing putty is some good stuff IMO. For awhile all I used was the metal glaze but now I only use the easy sand. I've tried Upol's Dolphin Glaze, 3M's Pirahana Putty, one made by USC and a few other no name brands, but I always come back to Evercoat. I never realized how flexible the stuff was, interesting.
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 01:22 AM
Adheision test. BarryK Body - Exterior 11 04-08-2005 05:01 PM
Which bondo should I use? Nightfire Body - Exterior 8 07-26-2004 06:38 PM
Glazing putty, When? Bluepen Body - Exterior 26 07-23-2004 02:22 AM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 10:34 PM
