pont. 2 brl to 4 kick down adj.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2013, 09:50 PM
76 pont.350 swap 2brl. to edelbrock perf ,q/jet and not sure where kick down should be or how to adj. it to proper adj. ? Ended up useing the e/b kit for throttle and kick down and that's on and looks like it's inline but not sure about kick down? Thanks
Old 07-22-2013, 07:13 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The detent (aka kick down) cable hooks to the carb throttle arm below the throttle shaft so the cable will be pulled out as the throttle is opened.
The detent cable has a lock that has to be released, then the throttle fully opened, then the lock re engaged to hold the adjustment. Old, worn cables can slip at the lock, so if yours won't hold adjustment you might need a fresh cable.
Be sure to open the throttle from inside the car (need a helper) and be sure there's nothing like carpet or floor mats under the throttle pedal, and that the throttle pedal is opening the carb 100%.
Exact adjustment instructions can be found online or by doing a search here.
76 pontiac F/B 350 2 brl. f/bird Hotrodding Basics 3 05-07-2013 09:00 PM
57 pontiac 287 edelbrock 4 brl manifold krazeyone Engine 10 01-29-2011 01:10 AM
Holley 4 brl experts in here. 1st rebuild. FrankR Engine 3 08-20-2008 11:12 PM
Oval track racing-2 brl Rochester mods? Graham Walker Engine 3 07-24-2007 09:59 AM
Holley 2brl or Edelbrock 4 brl? Bronco Engine 2 12-10-2006 03:28 AM
