Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pont. 76 350 cam break in procedure
Old 06-27-2013, 11:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by f/bird View Post
Would like any tips on cam break in for a edelbrock 2157 in a 350 pont. eng. other than the instruction sheet . Any special oil for break-in or for the first run ?
Cam break in
Should be a nice cam for you. Are you using the stock bottleneck rocker arm studs? If so, be sure the preload is correct!
