-   -   Pont. 76 350 cam break in procedure (http://www.hotrodders.com/forum/pont-76-350-cam-break-procedure-234423.html)
f/bird 06-27-2013 09:11 PM
Would like any tips on cam break in for a edelbrock 2157 in a 350 pont. eng. other than the instruction sheet . Any special oil for break-in or for the first run ?
cobalt327 06-27-2013 10:31 PM
Cam break in
Should be a nice cam for you. Are you using the stock bottleneck rocker arm studs? If so, be sure the preload is correct!
f/bird 06-28-2013 06:50 AM
I'm installing cam kit and q/jet with e/b performer intake,timing set,and the cam kit instructions said to replace valve springs so I'll need to do that also .I had not thought about any other parts except the harmonic balancer and water pump .
cobalt327 06-28-2013 05:34 PM
Info on Pontiac bottle neck studs here.
Other info that you may find useful:
Adjusting hydraulic lifters
Cam break in
Valve train points to check
Valve train geometry
Valve spring installed height
Pontiac info/sites
Pontiac engine info
