Pont. 76 350 cam break in procedure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2013, 09:11 PM
Would like any tips on cam break in for a edelbrock 2157 in a 350 pont. eng. other than the instruction sheet . Any special oil for break-in or for the first run ?
Old 06-27-2013, 10:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cam break in
Should be a nice cam for you. Are you using the stock bottleneck rocker arm studs? If so, be sure the preload is correct!
Old 06-28-2013, 06:50 AM
I'm installing cam kit and q/jet with e/b performer intake,timing set,and the cam kit instructions said to replace valve springs so I'll need to do that also .I had not thought about any other parts except the harmonic balancer and water pump .
Old 06-28-2013, 05:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info on Pontiac bottle neck studs here.
Other info that you may find useful:
Adjusting hydraulic lifters
Cam break in
Valve train points to check
Valve train geometry
Valve spring installed height
Pontiac info/sites
Pontiac engine info
T-350 break in procedure? PontiacPhil Transmission - Rearend 6 06-04-2010 09:23 PM
Break Bleeding procedure Furytom Suspension - Brakes - Steering 11 05-22-2009 08:11 PM
Rebuilt Chev 350 Break in procedure JD's camaro Engine 5 01-11-2008 08:32 AM
zz3 break in procedure claust Engine 2 10-09-2006 11:17 PM
Assembly and Break-In Procedure Meangreen Engine 8 12-04-2003 11:17 PM
