Pontiac 301 to 400 Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2010, 12:08 AM
Trying to do some research on a '79 Firebird 301 engine swap to a 400.. How difficult would this swap be? Would the 301's TH350 Trans work? What work would need to be done to get the 400 in there?
Looking for any information on this
Old 11-29-2010, 10:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you use a '70-up block, the swap is easy. The 301 has a shorter deck height than the other Pontiac engines, so some of the accessory brackets may be affected by this when used on the 400, but if you can, get the 400 w/as much of the front engine accessory bracketry as possible- unless you find that the 301's brackets fit.
The trans will bolt up w/o issue, as will the driveshaft. I'd recommend you run headers and plan on installing them when you swap engines to make it easier.
The radiator might be on the small side, unless the car already has HD cooling.
Old 11-29-2010, 11:21 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Also, if you intend to swap out the 350 for a 400 trans, make sure it's a BOP unit, or you'll need a bell housing adapter.
Old 11-29-2010, 04:45 PM
Onefunponcho's Avatar
2x on what cobalt said about the headers. Having installed a couple of f-body header sets it is so much better to install them with the motor out. I believe I made up some new swear words when I did a set in a four speed car with the engine in.
Old 11-29-2010, 05:17 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I had a bugger of a time trying to drop 389's into two different '65 GTO's with Hooker headers already on, both 4 speed cars. Couldn't do it.
Old 11-29-2010, 06:22 PM
I hear ya.... The only way it worked in my 67 lemans was while i lowered the engine into place I had to fish the zbar through the headers bolt it to its bracket first and guide it on the pivot while I lowered the motor onto the mounts. Was a mother the first time but after about 5 times in and out with the motor I got pretty good at keeping three things lined up with only two hands.
What a process
Old 11-29-2010, 07:17 PM
can you actually lower the motor in with the headers on? the 3 times ive done it i had the motor sitting just above the mounts. i think its a bear either way.
Old 11-30-2010, 09:37 PM
Thanks for the info! Quite helpful!
If i did the swap I would also be interested in using a Trans Am shaker hood scoop.. It sounds like the swap shouldnt be that hard but will the TA hood and scoop bolt up without any modification?
Old 11-30-2010, 09:50 PM
If you get the correct hood and the whole air cleaner assembly.
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
Pontiac 400 88bluebird Engine 8 12-04-2005 01:17 PM
Will a pontiac 400 fit CamMan Engine 10 11-21-2003 05:46 PM
will a 1969 455ci olds engine bolt right in place of a pontiac 400??? chevyelc81 Engine 3 06-12-2002 03:54 AM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 03:58 PM
