pontiac 301 to chevy 400 ????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 08:49 PM
i am doing this swap in an 80 trans am. i am using chevy motor mounts that dont line up on any hole pattern on the crossmember. Have u heard this kind of thing before? What suggestions do you have ? what have other people done in this situation? what i thought of is hooking the tranny to the engine and the driveshaft. dropping them in the car and mark the holes where the mounts need to go.then drill out custom holes on the crossmember.
does it sound like a good idea?
Old 01-21-2006, 09:01 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
That or weld it in place thats what I did on my 71 LeMans when I went from a 71 350 2bb to a 77 400 4bbl Pontiac of coarse different mounts from the year changes
"SlowRide66"
"Illegitimis non carborundum"
Old 01-21-2006, 11:59 PM
Are you using a 2nd-gen Camaro mounting system?
Old 01-22-2006, 06:31 PM
i am using the 2nd gen mounting setup
Old 01-22-2006, 07:01 PM
71 c-10's Avatar
just a kid and his truck
are you sure you have the correct mounts? my girlfriend is doing a simalar swap with an 79 T/A 301 to pontiac 400 but since the camaro and T/A should be built the same the mounting holes should be there i would think? Is there dirt and grime covering a hole, if seen it happen a lot on many a motor swaps i'v done, just a thought.
Old 01-23-2006, 06:03 PM
there are many holes on the crossmember but because i am not using the stock tranny, the motor sits farther up. i am using the turbo 400. all went well. I put the engine and tranny in in one piece, lined up the driveshaft so there was enough room for the yoke to move when the rear end moves and welded the motor mounts and tranny crossmember in place! id trust a weld before a bolt any day with the torque i'm going to have.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
pontiac 400 confusion custommccannix Engine 18 12-09-2005 07:27 AM
rebuilding my chevy 400 B-Body-MAN Engine 2 11-28-2004 08:19 PM
pontiac 350 vs 400 bb jjweb74 Engine 15 11-12-2004 02:30 PM
Will a pontiac 400 fit CamMan Engine 10 11-21-2003 05:46 PM
