pontiac 301 help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2004, 05:13 PM
pontiac 301 help
hello how is every body doing tonite. i am having troble putting together a 301 that im building. when i pulled the engine apart i # every thing. starting with the #1 driver side con rod. well i didnt pay to much attention. i also notched each rod so that it would be easy to install the pistons. well to day when i went to check the rods before piston installation. i noticed that 1357locking tabs where to the outside like they should be. 2468where to the inside. every engine i have ever seen has had the locking tab to the outside. also the chamfer is the same on both sides or the rod big end. hummmmm. thought maybe i numbered them wrong so i checked each rod . and there is no way i could have # them like that. if 2468 have there locking tabs to the outside my #s are to the inside. meaning it would either be realy hard to # them or imposiable. so i looked in a gm book. it said on 301 pontiac that there is a niple on the back of each rod. the niple is to point to the back of the engine. i checked and the way i have them all numbered all niples are pointed to the back of the engine. which would leave the locking tabs to the inside on #s2468. does anyone have any experiance on this. i need help. thanks alot
denny
Old 03-11-2004, 07:32 PM
any body out there
Old 03-11-2004, 08:20 PM
King of my Man-cave.
I'll check at work for you tomorrow.
Old 03-11-2004, 09:50 PM
Jared's Avatar
hey if they fit that way it should work that way do all the marks on the pistons face the same way? if not get a 350,400,421,428,455 they will all bolt in on second thought if you find a 421,428 or a 455 send it to me and i'll send you my 400 and pay shipping just to be nice.
good luck hope ya figure it out
Old 03-12-2004, 06:21 AM
i think we have a 428 at work ill check for you today. thanks for the help guys.
denny
