Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 350
Thread: pontiac 350
Old 10-03-2012, 08:38 PM
LATECH's Avatar
LATECH LATECH is offline
You should CC the heads to see just exactly what the chamber size in for both. Its the only way to really know where your compression will be at. None of the head charts I looked at are consistent, nor have they been accurate in the past, some yes and some not.
I am guessing the 94s will be smaller chambers, as the 64 are from a 455 , which usually means larger chambers due to cylinder size.
Fact is stranger than Fiction
