Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 350
Thread: pontiac 350
Old 10-03-2012, 07:54 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: New Gas Tank
The 350 will need the heads with smaller valves.The bore size restricts the clearance between the cylinder wall and the valve, causing valve shrouding, basically impeding flow. if you look at the top of the cylinder bore of the 350, you will see 2 notches in the top of the bore.This is a relief or "chamfer" to help airflow around the valve as it is so close to the cylider wall that it wont allow good airflow in that area without it.
Fact is stranger than Fiction
