Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 350
Thread: pontiac 350
Old 10-05-2012, 03:32 PM
robhardy's Avatar
robhardy robhardy is offline
carb is a street avenger 670 cfm. should be fine.
my only goal for this engine is a quick 0-60. the cam is 198 on the intake 212 on the exhaust with a lift of around 440 or somewhere.
going to have the heads re-surfaced and cc'd. the only question is whether or not the torker ii will destroy the low end torque.
i have a 76 stock intake. can that be modified to fit the 71 heads?
if that's not a cheap, simple mod and the torker ii will kill the motor off the line then a performer is probably the easy fix.
that cam probably plays out well before 5000 rpm's and i'm thinking i'm not running too big of a risk off the tires not grabbing with an almost stock 350.
so, the torker ii seems mis-matched to me. being wrong about that would make me happy.
