Pontiac 350 compression ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2010, 12:42 AM
I have a 1972 350 pontiac. the current compression ratio is 7.1:1 with a 117cc head. (what ive read) Im going to install pontiac 400 heads that are 87cc.
Anyone have a rough estimate on my compression pick up?
Old 07-21-2010, 02:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have no idea where your calculated CR comes from, but w/a 85cc chamber, a Pontiac 350 will have about a 7.85 CR. With a 117cc head, your CR would be around 6.3:1.
More: http://www.wallaceracing.com/cratio0001.htm
Old 07-21-2010, 09:41 AM
machinist & fabricator
i use closed chamber heads on my 354's, the small bore needs all the help it can get
Old 07-21-2010, 09:51 AM
I like this pontiac site.
http://www.projectpontiac.com/ppsite...tio-calculator
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
SHADE TREE: 3:50 Ratio SHADE TREE Transmission - Rearend 4 03-31-2006 02:27 AM
A compression ratio question Centerline Engine 7 11-20-2005 08:52 AM
cylinder psi vs compression ratio newchevyman Engine 2 07-06-2003 02:45 PM
compression ratio??? RedRocket Engine 1 10-25-2002 02:22 PM
