Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac 350 Motor/Intake Manifold setup question
Old 06-19-2013, 09:25 PM
LATECH's Avatar
LATECH LATECH is online now
If the cam you purchased recommends a higher stall speed converter than stock, you would be wise to use it.
If the cam says it pulls from 1300 and up, the stock would be OK.
Choose a converter with an estimated stall that is 200 rpm higher than the low end of the cams power band. LA
Fact is stranger than Fiction
