Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac 350 Motor/Intake Manifold setup question
Old 06-22-2013, 07:44 AM
LATECH's Avatar
LATECH LATECH is offline
You would be better off to run the 51-221-4 .
It would keep your dynamic CR down enough to run 87 In My Honest Opinion.
It is about the biggest you can run with catt wizz gas,tall gears, stock converter and 350 cubes .
Bigger cubic inches need bigger cams. Dont over do it on cam choice.
I agonized over my cam choice for almost 9 months before I finally chose th exact one. I had originally 3 different ones in mind.
ID:	75087   Click image for larger version
ID:	75088   Click image for larger version
Fact is stranger than Fiction
