Pontiac 350 Motor/Intake Manifold setup question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-22-2013, 01:51 PM
Well, we will have to see how it all works out. The engine is built and installed. I only have the top and interior left to do. I have done everything on the car except the motor. I was recommended this cam by Summit Racing. I live North of Atlanta and that is what they recommended. I bought everything at one time and figured it would work because they deal in this everyday and I don't.
Any idea on what it costs to change out a cam if everything else is newly built?
I really hate taking steps backwards in a build. So I may just have to see how it all works out.
SAM
  #17 (permalink)
Old 06-22-2013, 04:25 PM
LATECH's Avatar
Better put a 2500 or 3000 stall in that bad boy if youre gonna run that cam.
You wont like it trust us. We arent a saleperson trying to sell you something. All of the guys here have built engines (especially P Body ) and we know what works.
You want to take a step backwards..put that cam in . Big step backwards next.
Do what you want. Easy to change the cam now...later...not so much
Fact is stranger than Fiction
  #18 (permalink)
Old 06-22-2013, 04:29 PM
I guess it is too late now. The motor is in the car. Everything engine and transmission related is complete and working good. I just don't have a windshield or top and interior. So to change the cam now has got to be expensive. That is why I was curious on what it would cost.
SAM
  #19 (permalink)
Old 06-22-2013, 04:54 PM
LATECH's Avatar
Ok. Well get it running and greak in the cam. See what you have at this point.
If youre dissapointed in the low end /take off performance , that big cam will be to blame.
Like I said you could put a higher RPM stall converter in it. Which would be a quick round trip , pull the trans, swap converter and reinstall.
See what you get. Let us know how she turns out.
  #20 (permalink)
Old 06-22-2013, 08:38 PM
techinspector1's Avatar
Wiki Edits: 326
Just curious, I have not seen anywhere in this thread where the static compression ratio of the motor has been addressed. That's why I'm curious that you can tell the OP that it's too much cam. Not saying you're wrong, just curious.
  #21 (permalink)
Old 06-23-2013, 07:42 AM
LATECH's Avatar
You know I realized that last night after reading back through this thread.
I checked on a pontiac head chart somewhere and went with a stock 69 head chamber size when I originally made my statements. My Bad I should have asked him.
Maybe the OP will post his chamber volume and I can have a second chance here.
If his chamber size is about 72 CCs , the cam he has would be pretty good.
Maybe he will post the casting number.
#47 heads show to be 72 CCs
#48 heads were 64 CCs with press in studs (350) and were 72 CCs with screw in studs (400 ci)
Both head volumes would be Fine with his cam, of course the 64 CC heads would be real good. 93 octane would be needed as well.
intake manifold question Msgt Engine 2 03-21-2012 09:09 PM
chevy 350 intake manifold question sparkyct55 Engine 5 02-14-2008 06:07 PM
Intake manifold ID for 350 chev??? help!!! chevtruck Engine 4 08-31-2004 11:38 PM
Pontiac 400 Intake Manifold buckethead Engine 9 11-26-2002 12:42 PM
GMPP CRATE MOTOR Intake Manifold Vacuum alligator Engine 6 09-18-2002 08:02 PM
