Everybody and their brother has a Chevy 350, right? I'd build the Pontiac, just to do something different, and if it doesn't please you, a 400 or 455 will drop in easily, since they are identical in external dimensions to the 350.
If you do want to go with the Chevy motor, get some front springs and the motor mount system from a '68-'72 Nova or '67-'69 Camaro with SBC and use them. You'll also need a transmission that fits on a Chevy block, or an adapter for your current trans. Transmission mounts will be in the same place unless you decide to use a Turbo-400. |
By all means stay with the Pontiac. If your are not satisfied with the 350 in stock form then contact Ken (Ace) Brewer at Pacific Performance Racing as he has developed a stroker kit for the 350 Pontiac to where you can build to a 383 that makes 462 hp and is fully streetable and runs on pump gas. If that isn't enough then you could drop in either a 400 or a 455 whick is pretty well a direct bolt in.
I say keep the Pocho 350 as well. The money along you'd spend on just the ancillary parts needed for the swap could be spent on the Pocho. Years ago in one of the magazines they covered a Pontiac 350 build up. I forget who the dyno operator was but he was one very well known to just about anyone who reads a car mag. He didn't believe from the power made that it was just 350 cu in. He had to verify my measuring that it really was a Pontiac 350! IIRC, the Ventura that the engine went into was running high 9's, NA.
I love the Pontiac powerplants. Put them in most my rides. You can build a nice 400hp Pontiac relatively inexpensively. Besides they are low winding tourque monsters, and that nice wide block looks awsome in any rod. Stay with the Poncho!!
BOP 350 in a chevy???
Not trying too hijack his thread... but I'm thinking similar thoughts.
I have a 350-350T from a 71 BOP (assuming Pontiac) what do I have to do to squeeze this in my 1965 Chevy II? Really, I'm going to do it starting tomorrow, other than motor mounts and oil pan issues, what else should I expect? |
posted by gonzo II: "what else should I expect?"
If what you have is a Pontiac 350, in that light Chevy II body, you'll have one fun street machine, with enough torque to just about rip your head off. The Pontiac 350 (actually 354 cu in), internally, is exactly the same as a 400,except for the piston diameter. Other than the pistons, everything else is interchangable, including the intake manifold. So you could put an early 70s 4bbl manifold on it. To be sure if it's a Pontiac 350, check for a 2 letter code that would be stamed above the water pump on the front of the right bank, and the heads should have a 94 cast on the top of the two center exhaust ports. Good luck and have fun! |
it has the intake/4bl
The engine has a Qjet 4 on the intake
It is stamped 71 under the distributor and 350 on both sides of the block. I'll look for more stamped numbers in the morning. It does have VERY small numbers stamped in the block, drivers side front, on a small tab just under the heads.... can I cross reference this number anywhere?? The transplant begins Saturday |
"It is stamped 71 under the distributor and 350 on both sides of the block."
Is the 71 stamped, or is it cast on? I don't know of any Pontiacs having the year stamped on. Does this engine have an oil tube at the front to put oil in, or is the only place to add oil, the valve cover breathers? |
the '71' is cast
Yes, I meant cast... 71
the oil filler is up front, directly above the water pump |
"the oil filler is up front, directly above the water pump"
That would make it an Oldsmobile 350. Bigger bore and shorter stroke than a Pontiac (4.055 X 3.385 vs 3.875 X 3.75). Still a good engine, but I'm into Pontiac, HARDCORE! |
OK, it's an OLDS
But same questions now apply.
I found a 71 Catalina in the local scrap pile, can I steal those engine mounts, exhaust manifolds and get away with putting them on the Olds.. I know, I will have to do my own motormount mods to make it work, but do they bolt straight to the Olds? And dif' stroke, what will I see in the car? Hey - I've only rebuilt imports up til now, but 50 and I always wanted a rat rod. Thanks for all your help. |
If the Cat had an Olds in it, you could probably use the mounts, but I don't know for sure. Like I said, I'm into Pontiacs, and that means traditional Pontiac engines.
I have a '69 pontiac 350 H.O. in my '65 skylark and i love it that thing runs like a raped ape and its not even worked other than a holley 4160. but since your planning on running the olds you need to either custom fab motor mounts or find a nice set out of another olds car that you know had an olds motor. as far as tranny goes GM mounts are universal but you need a TH-350 that is for an olds. they are all generally similar except for the shape of their bell housing of whatever you whish to call it (the part that bolts to the rear of your motor) some are round i think the chevys are round the pontiacs have a dip in the top. idk as far as the olds but all the mounts for the tranny will work.
let me know if you have any more questions. -Jack |
| Power Steering for my 53 Pontiac Chieftain | pontiac53 | Suspension - Brakes - Steering | 1 | 10-24-2007 09:29 AM |
| chevy 350 or pontiac 400 or 455??? | MIKE T | Engine | 17 | 02-04-2007 07:34 AM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 17 | 01-06-2007 09:11 PM |
| putting a chevy 350 into a 1979 pontiac firebird | gwarren | Engine | 11 | 02-03-2004 12:50 AM |
| Is the Pontiac 350 considered a big block? | PD69 | Engine | 9 | 07-23-2003 11:00 AM |
