Pontiac 350 valley pan question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 11:47 PM
Hi guys im still trying to track down a vacuum leak on my pontiac 350, so if my valley pan is not completely sealed will that cause a vac leak?
right now it idles at 1000rpm in park but in drive it is 650 rpm i sprayed starting fluid all over the intake manifold and carb and no change in idle. i only have two vacuum lines, one for the modulator the other for the distributor and both are new. distributor is new as well.
Thanks in advance
Old 08-03-2012, 01:00 AM
WDCreech's Avatar
Grumpy Old Goat Herder
No it won't. You have some other problem!
Bill
Old 08-03-2012, 07:27 AM
No PCV valve? There should be a vacuum line (large) to that. Power brakes? Another large line. Unless this is a track-specific application, you really NEED a PCV valve.
Could be too much cam for the torque converter. That can cause this symptom.
Jim
Old 08-03-2012, 07:32 AM
check the carb gasket & intake manifold & make sure they are tight.
Old 08-03-2012, 08:34 AM
Oh yea I do have a PCv valve its new and the line and grommet too. I got the intake manifold used and even with felpro gaskets I had to put a bunch of sealer around the water jackets otherwise it would leak coolant. Guess I might buy a new intake since this one might be warped. But I did spray starting fluid all over and no change in idle
Valley pan gasket? roadlet_411 Engine 7 06-04-2010 10:06 AM
Valley pan vortec david ahluwalia Engine 5 03-19-2009 04:43 PM
New 318 Poly Valley Pan Under Development Abomination Engine 0 03-14-2007 06:56 AM
Pontiac valley pan question jay67 Engine 4 01-06-2006 07:50 AM
429 valley pan needed? Jared Engine 4 12-25-2003 08:28 PM
