Pontiac 350 valve noise
I recently picked up a 68 tempest with a non-original late 60's 350. There is considerable valve noise on the drivers side. I removed the cover and found 1 out of all the rocker nuts a little loose. I tightened it down like the others. Didn't seem to help much. From what I have read, I must have the "net lash" system. Can anyone recommend the next steps to solving the noise problem?
Could be the rocker arm and pivot ball is worn out. Also press in studs can pull out creating excessive lash and a tick or tap. Lack of oiling due to sludge,plugged pushrod holes and excess clearance in bearings (worn engine) can all cause lack of oiling.
Being the drivers side oils before the passenger side, chances are the rocker stud may have pulled out .
Fact is stranger than Fiction |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
18436572 (08-08-2012) | ||
| pontiac 350 valve train damage question | lucky13firebird | Engine | 5 | 12-29-2011 11:32 PM |
| 03 Pontiac Grand Prix - Growling Noise | S10 Racer | Transmission - Rearend | 4 | 11-21-2010 05:19 AM |
| Pontiac 400 engine noise | Purserrobert | Engine | 1 | 06-26-2008 09:15 AM |
| valve noise..... | Icelander | Engine | 9 | 07-02-2007 06:14 PM |
| valve noise | big red 1 | Engine | 5 | 10-04-2006 09:52 PM |
