Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 350 vs 400 bb
Old 10-27-2004, 12:32 PM
70SPORT's Avatar
70SPORT 70SPORT is offline
400 will be quite a bit better...you will have to go through it...i would put a cam in it....port the heads put on a torker 2 intake port that to match the heads........if you have money buy aluminum heads and port them......better fuel pump......700-750 double pumper carb.......rockers of your choice......just a few things that are not alot of money to produce some good horsepower......if you have time its the way to go...the aluminum heads are expensive but thats about it....if you have 6x heads thay are real good i would just port them and you should be at about 375-400 hp at the crank
