Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 350 vs 400 bb
Old 10-27-2004, 02:36 PM
70SPORT's Avatar
70SPORT 70SPORT is offline
Originally posted by Siggy_Freud
There are a lot better intakes than the Torker 2. Look at a few of the others on the edelbrock line and just do some general research online.
torker 2 is great for the price...there sure are better intakes but for the money you cant beat it....my .02
Originally posted by paperairplane
Pontiac engines aren't large or small block. Externally a 326 is the same as a 455.
Put the 400 heads on the 350 and change the cam you should be good to go and save a lot of effort. Then take your time and build the 400 into a monster.
its not just a matter of switching heads...the stroke is different in a 400 vs a 350. your right externally they are the same. its more then heads and cam...In a 455 the crank shaft is way bigger as well as the bearings....forged crank in a 455.....a lot beefier
