Pontiac 4 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2002, 07:04 PM
Post Pontiac 4 speed
What 4 speed transmission came in the late 60's mid 70's big block Gto & Trans Am cars? and would these be worth swapping into a one ton GMC?
Old 10-30-2002, 05:33 AM
SAE Member, ASE Master Cert.
Post
The GM cars of this era had either Muncie or Saginaw four speed. Both are good transmissions for light vehicles and the Muncie is generally accepted as the better transmission. Don't think the effort would be worthwhile to attempt putting either one into a 1-ton truck, IMHO.
Old 11-06-2002, 06:32 PM
Post
Hey dude, if you're looking for the big bad A55
4-speed, that would be a M-22 Rockcrusher, she'd work good in your pick-up, if you don't care about mind altering gear whine from those tough, straight cut gears.
Keep on roddin' <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
