Pontiac 400 cam choice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2002, 10:48 AM
Question Pontiac 400 cam choice?
Found out last week that the cam in the engine I'm going over was junk (collapsed one lifter and flattened a lobe), and I've started looking at replacements. It's for a 1973 Pontiac Firebird that's had major head work done by the previous owner - gasket ported, 1.77/2.11 valves, and "milled to 65cc" according to the spec sheet that came with the car.
So I'm looking at compression at or above 11:1, but otherwise a really nice set of heads, stock crank and connecting rods, and TRW stock-equivalent pistons. Drivetrain is a T-10 with 4:10 posi, and 15" tires.
What cam specs would you suggest I look for for a streetable ride? Any help is appreciated. -zac
Old 11-15-2002, 11:06 AM
F-1Rodder's Avatar
Post
You may want to look to a cam with enough duration and overlap to bleed off some of that compression.
Old 11-18-2002, 01:48 PM
Post
I would recommend the RAIV replacement cam either from Crane or Crower. Lunati makes one similar, too. I'v heard good reviews about the larger of the Summit Racing Cams they offer.
Old 11-18-2002, 05:43 PM
Post
i was looking at summit's #2802;
duration @ .050: 224 intake/234 exhaust
lift: .465 in. intake/.488 in. exhaust
separation: 114 degrees
RPM range: 2,500 to 5,000, which works well with the 4.10 rear gears and 4-speed.
for $87 for the kit, I'm tempted to just go for it - any other ideas?
thanks again.
--zac
Old 11-19-2002, 06:47 AM
Post
That would be a very good kit for that motor. I know someone that used that same kit and loves it.
Old 11-19-2002, 03:52 PM
Post
thanks!
Old 11-25-2002, 02:12 PM
New Member
Post
i am running a GTO with a 468 with a ra1v wirks just great but you ain't going to like that 4:10 Pontiac's are grunt engines and don"t like a lot of rpm's I use a 3:73 and put in a built 200r4 just so I could drive it on the e-way other wise I was twisting 3000 rpm at 60 Just my 2 cents worth
Old 11-25-2002, 03:27 PM
bullheimer's Avatar
NEVER use credit cards!
Post
i'll quote you from "best bolts ons" HRM 5/2002 "Stock camshafts even the ram air iv are totally obsolete. ...pontiacs respond much better with modern cams." i do not know if the "new" ram air iv cams are same or different than stock. Bruce Fulper goes on to say he has comp cams make a grind of his own that will work with 1.5:1 rockers, his phone is 909-370-0389 and <a href="http://www.pontiacengines.com" target="_blank">www.pontiacengines.com</a>
Old 11-25-2002, 05:20 PM
Post
i personally don't have the $ for a comp cams grind, can buy 2 or 3 summit cams for the same price and i won't drive it hard enough long enough... thanks tho
Old 11-26-2002, 07:23 AM
Post
Bullheimer, The RAIV cams I was referring to are NEW designs. They are the Cam manufacturers replacement for the RAIV cams......new computer designed....
Steppenwolf, The Summit cam is not a RAIV cam, but it is a very good cam and you'll be happy with it. Should have a little lope at idle.
