pontiac 400 cam selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2007, 07:02 PM
i am trying to find a cam for my stock 400 is a crane 260 h suitable for a daily driver , or step up to a 268 h .. i will be replacing the heads also for a set from 67 ... thanks
Old 08-20-2007, 08:51 PM
Originally Posted by F-BIRD'88
Crane cams "blueprinted" copy of the old factory Pontiac 400 HO RAM-AIR "S" cam will work very well Crane number 9779068
do you think this cam will work with the 67 #143 heads -10.5 comp .would it run on pump gas our would comp be to high
Old 08-21-2007, 09:59 AM
ok thanks alot . i think they are 68 0r 72 cc . these are the 325,333 hp heads made before the famous 670 . they are also closed chambered . but i will do the math
Old 08-23-2010, 06:45 AM
old thread worth reviving- the best cams for a street Pontiac are the factory 068, or the Comp Cams 268
Old 08-23-2010, 07:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One thing you will find w/an original 068 cam is the wide 114 LSA. A decent cam is the Summit K2801. It has 214/224 duration, .442"/.465" lift, 112 LSA and is sort of a higher lift version of the 068 Pontiac cam.
FWIW, his '67 "143" heads were dropped mid-'67 for the "061". The 143's didn't have guide plates, both had 2.11"x 1.77" valves.
From HERE:
PONTIAC 068
intake open 31
intake close 77
exhaust open 90
exhaust close 32
overlap 63
lift .408 w/1.5:1 rocker ratio
duration adv 288/302
duration @.050 212/225
LSA 116 ICL 113
Old 08-23-2010, 10:32 AM
PONTIAC 068
intake open 31
intake close 77
exhaust open 90
exhaust close 32
overlap 63
LSA 116 ICL 113
Yes I realize that, I've run the 066, 067, 068, 041 RA IV, along with the Comp 268, and Summit 2800, 2801, 2802, in 350, 389, 400, 455 engines. Have also built 428 engine but not with stock cams.
Have run 2801 on a 455 with 1.65 rockers, lots of torque, but runs out of breath and rpm at 5200 with stock D-port heads.
The Summit cams- 2800 is way too small and runs out of breath at a very low rpm, 2801 will rip your head off to 5200 rpm in a 455 but then shuts off like a rev limiter, 2802 has lopey idle and less torque midrange, and with stock heads won't rev over 5200 rpm anyway on a 455, because the stock heads become a restriction
having run both 068, 2801, and Comp 268, I'd have to say the Comp 268 is the best, if I had a choice- I'd take that over a Summit 2801
if I had to choose between the 068 and 2801, I'd take the 068, the wider LSA actually helps it rev a little higher with that small cam lobe, and give better mileage in a street car
it's hard to beat a stock Pontiac cam, because McKellar was such a good cam designer, the newer cams really can't improve much on what he did
race cams are another story, the newer stuff whips the old stuff
I had a pair of "061" heads, sold them on Ebay, they had unique chambers. I've also run 455HO #191 round port heads, casting #12, #13 heads w/041 cams, on 350, 400, 455 engines.
check your sources, because the casting "143" heads are listed as having 1.92/1.66 valves, not 2.11/1.77 size
pontiac 400 confusion custommccannix Engine 18 12-09-2005 08:27 AM
Pontiac 350 cam wein77 Engine 4 11-26-2005 07:12 PM
Pontiac 400 valve adjustment HORROR!!!! please help Chris Mitchell Engine 7 11-26-2005 12:34 AM
Pontiac 400 badzzam Engine 3 08-08-2005 01:30 AM
cam for a pontiac 400 greg67 Engine 3 12-21-2003 11:45 PM
