Pontiac 400 falls flat at 4500 rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 10:39 PM
JTL JTL is offline
I have a 72 pontiac GTO with a 400 in it 750 carb edelbrok big cam etc. Sounds cool and starts strong but usually falls flat around 4500 rpm
Old 01-15-2012, 10:58 PM
DoubleVision's Avatar
This could be several things so I'll list the most common. First, do the valve springs match the cam? If not it's to be expected it won't rev far as stock springs aren't designed to the pressures a high performance cam produces.
If the springs are up to snuff then that leaves ignition timing low, ignition spark weak, or the carb is not getting enough fuel to support high RPM operation. Lastly what exhaust system is on the vehicle?
Old 01-16-2012, 01:22 PM
JTL JTL is offline
I frankly don't know what the builder did but I believe the cam springs and lifters were done together from a set. Ignition is a DUI summit knock off. Exhaust hooker headers and 3 inch dual flow masters. It dawns on me that I have never changed the fuel pump. It could be original or at least old.
454 bad misfire around 4500 rpm tuff82 Engine 5 06-19-2011 08:07 PM
CAMSHAFT FOR 350 (Idle to 4500 rpm) adantessr Engine 13 07-16-2010 11:40 AM
454 Falls flat on face at high RPM 454headache Engine 15 04-09-2010 12:41 PM
building a 500+ hp sbc for under $4500 Tryin2MakeIt Engine 28 07-23-2009 02:14 PM
1932 Pontiac Flat 6... Help Me Old Tymers!!!! hotrod389 Engine 1 07-25-2006 09:47 AM
